Calibration gcode
tetranet
(@tetranet)
Calibration gcode
HEllo, i'm Marc From France. I'm very happy to have a Prusa MK2: its my first Prusa Original.
I have a small problem. When i launch the calibration Gcode from the SDCard, at the five point, my extruder is crash on the hotbed (i must buy another certainly after i will solve this problem.
If someone could help me it would be fantastic
Marc
Veröffentlicht : 23/06/2016 6:37 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Calibration gcode
Hi Marc
Seems that you meed the latest beta firmware 3.0.4: http://shop.prusa3d.com/forum/original-prusa-i3-mk2-f23/beta-fw-3-0-4-with-automatic-calibration-point-ali-t1108.html
Peter
Veröffentlicht : 23/06/2016 6:51 pm
christophe.p
(@christophe-p)
Mitglied Moderator
Hi Marc from France 🙂 (Chouette, je ne suis plus seul ^^)
First thing you need to ensure is that the probe is inside the circle of the 9 calibration point during calibration process.
Most of the time, this can be achieved by fine tuning the frame position (double check the 100 mm in step 10 here: http://manual.prusa3d.com/Guide/2.+Y-axis+assembly/104 ) and alignment (as described in the preflight video ehre: http://www.prusa3d.com/buildvideoMK2 at 7:38) .
Ensure also that the probe is not to high, the sticker on the PINDA probe pictures can mislead you to find the right position, the bottom of my pinda probe is more or less 1 mm above the bottom of my nozzle for example.
Try to check that first, and please share the result.
(and not that you will be hung for that, but there is a dedicated mk2 section on the forum 😉 )
I'm like Jon Snow, I know nothing.
Veröffentlicht : 23/06/2016 7:11 pm
tetranet
(@tetranet)
Hello again,
With the beta firmawre calibration is ok (thanx PJR). But we have a bug. If i stop the calibration gcode the bed don't stop and heat the front.
And "Merci" Christophe for your precious help 🙂
Now i try to setup the probe 🙂
Marc
Veröffentlicht : 23/06/2016 9:05 pm
PJR
 PJR
(@pjr)
Marc
Stopping the printer during a print; that was a fault in previous versions of firmware; must have returned with the beta.
Josef will probably read your comment and get it fixed.
Peter
Veröffentlicht : 23/06/2016 9:46 pm
tetranet
(@tetranet)
Hello,
I made few print to try
It seems all ok. Quality is fantastic 🙂
But if i try to send another print, i lost calibration and for each print i must do a calibration. I think i do a error.
And my hotbed is not perfect :
Here thats ok :
But not here :
Veröffentlicht : 27/06/2016 4:33 pm
