[Closed] Benchy trouble shooting
Stránka 2 / 2
elliot.l4
(@elliot-l4)
Re: Benchy trouble shooting
Yes, I managed to get a good print using the gray filament without roughtness
Gz!
I started a print trying your speed and damn the edges are slow. I feel like using this speed is compensating to negate the real problem.
After like 5 hours, i managed to unclog the cold end! Printed this with default slic3r PE with 190 degree.
The boat with S3D was better looking
The boat at a higher temperature was better looking
All edges are rough on the bottom section of the boat!
Napsal : 16/09/2017 5:10 pm
elliot.l4
(@elliot-l4)
So i changed my extrusion width from 0.48 to 0.40 and it fixed alot of problems!
Print speed 60mm/s
outline 40%
Napsal : 17/09/2017 9:16 pm
Ido
 Ido
(@ido)
I tried printing with 0.40 extrusion width, its indeed a bit better, but not perfect.
Last thing I am going to try is print another fan nozzle ( https://www.thingiverse.com/thing:2276997 ), but I need to try my nylon filament first before I can use it.
Napsal : 18/09/2017 8:09 pm
hugonl37
(@hugonl37)
Print speed 60mm/s
outline 40%
Reviving old thread.. that looks beautiful! This was at 0.1mm right? No stringing on the cabin? How did you do that! What are your retraction settings may I ask?
Cheers!
Napsal : 02/10/2018 12:12 pm
Stránka 2 / 2
