Bed doesnt fit, so its impossible to assemble
anders.a
(@anders-a)
When trying to mount the bed I ran into problems.
The 4 screws in the corners fits just fine, but the 2 screws in the center does not.
It seems like the holes in the metal plate, doesnt fit the mounted nuts on the bed...
BR
Anders Lange
Posted : 05/04/2017 1:14 am
anders.a
(@anders-a)
Re: Bed doesnt fit, so its impossible to assemble
By the way, I have also tried to mount to 2 center screws first. They fit fine, but then none of the four corner screws fit...
Posted : 05/04/2017 1:39 am
have you ensured that the marker on the frame is in the correct location.
this issue has been reported a number of times. the screws in the 'middle' of the bed support, are not in the centre... you must have the frame the correct way up and the right way round...
regards joan
Posted : 05/04/2017 1:46 am
anders.a
(@anders-a)
Spot on, That solved my problem.
Thanks a lot for your help.
Posted : 05/04/2017 2:28 am
Tom@Conn
(@tomconn)
I had this problem as well. However my bed was installed the right way. What I found was that the instructions did not tell you (or I failed to notice) to back out the two screws in the middle after taking off the temporary nuts, thus the screws were pushing up the middle of the bed as I tried to mount the corners. I managed to mount the corners but could tell it was not true. After much frustration I noticed the middle screws pushing up the middle of the bed. I backed them out and restarted. However now none of the attachments wanted to pull flush. I then proceeded to give each receiving nut on the bed a test fit of the screw and noticed some initial resistance but gently worked each screw in and back out making sure to use same screws in same locations. Given how little bite each screw has I worked each one just enough to catch and then alternated tightening until I managed to get the corners and middle flush. So far so good.
Posted : 23/04/2017 5:13 am
