X axis belt grinding on idler
Hi everyone,
just noticed that my x axis belt is grinding on the idler and leaving behind rubber...How do I fix this? Maybe it is the cause of some of the ridges along the prints.
Problem is...I can not get the belt to be in the middle of the idler....Impossible.
Respondido : 04/04/2017 11:12 am
Re: X axis belt grinding on idler
The only adjustment I know of is on the other side where the motor is by loosening the motor gear and adjusting it front or back depending on the angle you need
Respondido : 04/04/2017 11:43 pm
