Verbatim ABS White - Problem
Hi! I have problem with printing White ABS. I have tried with brim, slow down printing, speed up printing, last on my mind is that ABS maybe have moisture but it's newly open package.
My temperature was 255-262C for Head and 110 for bottom. I have problems on the edges, middle is perfect. Also just to mention it is the same with improvise enclosure and without. The room is at stable 45-50% moisture and 24C*. What can couse this, extrusion multiplier. If can help I can insert 3mf or gcode.
Opublikowany : 17/09/2023 5:26 pm
