					                		two rolls, one bad? - Print tips (Archive)                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-print-tips-archive/two-rolls-one-bad/</link>
                <lastBuildDate>Sat, 07 Mar 2026 00:05:03 +0000</lastBuildDate>
                        <title>RE: two rolls, one bad?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-print-tips-archive/two-rolls-one-bad/#post-231867</link>
                        <pubDate>Mon, 20 Jul 2020 20:39:25 +0000</pubDate>
                        <description><![CDATA[Thanks Peter,I&#039;ll give it a try.George]]></description>
                        <content:encoded><![CDATA[<p>Thanks Peter,</p><p>I'll give it a try.</p><p>George</p><p> </p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-print-tips-archive/">Print tips (Archive)</category>                        <dc:creator>master moccasin</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-print-tips-archive/two-rolls-one-bad/#post-231867</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-print-tips-archive/two-rolls-one-bad/#post-231835</link>
                        <pubDate>Mon, 20 Jul 2020 19:31:20 +0000</pubDate>
                        <description><![CDATA[Clean bed with dish soap.Make first layer 100%.As extra you can try, more heat on bed, more heat on extruder during first layer, first layer slower, clean nozzle before printing.Water in fil...]]></description>
                        <content:encoded><![CDATA[<p>Clean bed with dish soap.</p><p>Make first layer 100%.</p><p>As extra you can try, more heat on bed, more heat on extruder during first layer, first layer slower, clean nozzle before printing.</p><p>Water in filament? dry it in a oven.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-print-tips-archive/">Print tips (Archive)</category>                        <dc:creator>Peter M</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-print-tips-archive/two-rolls-one-bad/#post-231835</guid>
                        <title>two rolls, one bad?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-print-tips-archive/two-rolls-one-bad/#post-228245</link>
                        <pubDate>Mon, 13 Jul 2020 01:46:55 +0000</pubDate>
                        <description><![CDATA[​I&#039;ve been using Prusament filament from when I first got two I3 MK3S printers. I recently got 2 rolls of vanilla white PLA and ran most of it on the CraftBot XL FLOW. I needed to start an 1...]]></description>
                        <content:encoded><![CDATA[<p><strong> ​</strong>I've been using Prusament filament from when I first got two <a href="https://shop.prusa3d.com/en/51-original-prusa-i3-mk3s">I3 MK3S </a>printers. I recently got 2 rolls of vanilla white PLA and ran most of it on the CraftBot XL FLOW. I needed to start an 18 hour print so switched to the second roll. It will not stick and or wads up and gets drug around. I tried it on both of the I3 MKS printers and got the same result. I then put the first roll back and tried thinking the file may be corrupt and it worked as expected. I then tried the first roll on both of the I3 MK3S printers and both were perfect. Is it possible I got a bad roll of filament?<strong>​</strong></p><p>George</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-print-tips-archive/two-rolls-one-bad/#post-228245</guid>
