Slicer settings for kit's demo prints?
MikeOShay
(@mikeoshay)
I put together the MK2S Kit, and by far my most successful print with it has been the Triceratops skull that was pre-loaded on the SD card. Most of my prints since then have had small but critical errors, like layers splitting apart, issues with adhesion, or poor infill and supports.
Does anyone know what software and config settings were used to set up that model, or the other ones put onto that card for that matter?
Postato : 23/11/2017 8:47 pm
AJS
 AJS
(@ajs)
Re: Slicer settings for kit's demo prints?
If you open the gcode file in a text editor, you can see all the settings as comments at the bottom.
I think your issues are under extrusion or clogging. Look here for some common causes:
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
Postato : 25/11/2017 6:26 pm
