Slicer Settings
mitch.m
(@mitch-m)
Slicer Settings
Hello there I have stated to print other peoples files and when I try to print them for some reason every single one starts the printing process at .5 while the files the prusa comes with starts the print at .23 and it actually prints out nicely. For some reason I can only the prusa files to print properly while any other file does not come out as well. Is this because my slicer settings are wrong? I am using the slicer program you guys provided and I'm still having trouble. Here is a picture a lego brick I'm trying to print.
Posted : 05/07/2016 8:51 pm
norris.m
(@norris-m)
Re: Slicer Settings
I had the same problem my solution is the z offset setting in slicer. you may have to play around with it but I found it helps.
Posted : 06/07/2016 3:27 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Slicer Settings
Download the latest drivers, install everything. Make sure you rung the Mk2 slicer from the new desktop shortcut. Select the correct profiles for your mode;, filament and printer.
Peter
Posted : 06/07/2016 9:18 am
