Silc3r Prusa edition - Filament used and cost calulator
Hello, i have been using repetier and cura in the past.
I can't seem to find after slicing, information about how long the printing takes, how much filament and i suppose as filament settings has $/kg box it should say cost of printing by filament used.
Thanks
Re: Silc3r Prusa edition - Filament used and cost calulator
After you save the gcode it will display the cost and filament used.
This is not very user friendly indeed. It should show after pressing "Slice now", but it only does after either "Export G-Code" or "Send to printer"
I agree 100%. The sliced file exists somewhere, probably a temp directory, for it to be able to show the layers, paths, etc. There should be no reason they couldn't make this happen.
