Pagina 2 / 2
Precedente
RE: Problems Printing Flexfill 98A
@paul-06 and joantabb
Thanks. I will try both and post it. Might take a while one print takes ~17 hours.
Postato : 06/02/2020 9:03 pm
Hello!
When the filament gets jammed it is an issue of the temperature of the extruder motor. I tinkered on this a lot. With information from this link i could solve it with a ventilator that I used for cooling the extruder motor:
In this link is also written about a line of code that you can use:
M907 E410 ; SET LOWER EXTRUDER CURRENT
When I first used this I ran into another issue, so I cannot tell you if the line itself works. The motor didnt get as hot as without this line. The new issue doesn't come from the line. Since it appeared one day later again, with my ventilator solution. Sadly... but no more jams for now.
Postato : 24/05/2020 7:24 pm
Pagina 2 / 2
Precedente
