[Closed] Problem with Printing after MMU install
ten13th
(@ten13th)
I am at a lost on what is causing my printing issue.  This issue started approximately after I installed the MMU.  I'm on the latest MK3S/2.5S and MMU firmware.  The best way to describe the problem is the printer would act as it is not getting enough material so it would air print or underprint a section.  First layer would be fine for the most part, with some spots that is underprint.  The problem really shows up on the fill layers.  I have slow down the speed to 70% but without improvement.  I have even installed a brand new hotend to make sure there is no blockage in the hotend.  I have also tightened the tension on the filament gear, should I tighten it more?  I see the same problem with PETG and PLA.  Any thoughts on what might be the cause of this problem?  And remedy for it?
This topic was modified 6 years ago by ten13th
Posted : 21/10/2019 11:04 pm
CCryder
(@ccryder)
RE: Problem with Printing after MMU install
After doing an MMU install (and also building a dry box), I had similar issues.  They were caused by too much friction in the filament path.  Do an extract filament (front panel command) which will push the filament out the front of the MMU.  Pull on it to see how much force is required.  I'm still working on a satisfactory solution, but it involves going to the 6 mm PTFE tubing in all the filament paths.  When I'm satisfied, I'll put it up on Thingiverse.
Posted : 17/11/2019 3:17 am
Hi Carroll,
I use 2.5 X 4 PTFE for all tubes except the one in the extruder cold end
Posted : 17/11/2019 9:26 am
CCryder
(@ccryder)
Hi Joan--
Thank you!  I did not know that this was available.
Regards,
Carroll
Posted : 17/11/2019 7:11 pm
rmm200
(@rmm200)
Bulk PTFE is readily available. Buy from a reputable 3D Printer supplier. Double check the bore is centered - and big enough.
Cutting jigs are available on Thingiverse, and Prusa has published detailed charts on cutting and tapering.
Posted : 17/11/2019 9:45 pm
@joantabb
Exactly these PTFE tubes I use and they reduce the friction caused by the filament transport considerably, but it's not so easy to find a shop (germany, austria).
Posted : 17/11/2019 10:06 pm
CCryder
(@ccryder)
Thanks, everyone, your comments are very helpful.  There's certainly plenty of cutting jigs to pick from on Thingiverse!
Posted : 18/11/2019 5:09 am
