Newbie question - Simple Circles
How do I get simple circles to come out smooth and not looking segmented ?
RE: Newbie question - Simple Circles
Design them with higher resolution (it is not the printer's fault).
Let me add more info, I am using Inventor Professional and creating rings to dress up a 1.25" hole entry. When I extrude and fillet the edges it renders smooth. Once I bring it into the slicing software it renders smooth. When I print it it comes out in a diamond style cut edges.
I tried a revolve and it printed smooth edges.
Not blaming the printer just trying to learn why this was happening. i.e. a setting that I have not discovered ect..
thanks for the response.
If you are talking facets on a ring, where it becomes a poly rather than an arc, then that's 100% inside your CAD software. Nothing to do with the slice.
pps: some day I'll learn to special and type, I promise ... lol.
Try checking your settings for stl export. In my CAD Software (Solid Edge) you can pick different resolutions for exported STLs.
