How to print?
I've only just began my foray into 3d printing and am loving every minute of it. I have tried printing a few miniatures for my D&D group, with some successes and a few failures. My question is this, How do you get something like the following to print? There is no support for the arms and they always seem to mess up because of this. Is there a way to add supports or should I alter some of the setting in Slic3r?
Re: How to print?
Yes. It is a Slic3r (or any other slicer) option.
http://manual.slic3r.org/expert-mode/support-material
View in PREVIEW mode to see the supports and ensure they will work.
Re: How to print?
http://www.instructables.com/id/Guide-to-Slic3r/
Re: How to print?
Another option is to edit the object and "cut" the arms off of the body and print them separately. Then just glue the arms back on.
- 1st "printer" TIKO 3D
- 2nd PRUSA i3 MK2S with MMU v1
- 3rd PRUSA i3 MK2S
- 4th PRUSA i3 MK3 with MMU v2- 5th PRUSA i3 MK4 (upgraded from MK3) with MMU v3 (upgraded from…
Re: How to print?
Wow, tons of options. Thanks a lot guys.
Re: How to print?
What model is this ? I would like to print it myself 🙂
Re: How to print?
https://www.shapeways.com/product/HVR869QWE/tiefling-female-wizard?optionId=62948821&li=marketplace
