High temp filament help needed
adrian.s2
(@adrian-s2)
I have the Prusa i3 Mk 2 with the full metal hot end.
I need a filament that has a heat deflection temp around 100C.
I've been thinking about Polycarbonate but with an extrude temp of 300C, can the Mk2 handle this?
Also, anybody got any suggestions as to another filament that may have the 100C ( ish ) capability?
Another interesting one is the Taulman Blu-Print but this seems hard to come by. (i'm in the UK).
Thanks in advance.
Posted : 15/11/2016 5:01 pm
adrian.s2
(@adrian-s2)
Re: High temp filament help needed
Oh, just to add, my go to filament is PETG but it gets a bit soft at 100C.
Thanks.
Posted : 15/11/2016 5:02 pm
Omikron
(@omikron)
Perhaps this is a bit too obvious of a response to be what you're looking for, but have you already tried ABS? It has a deflection temp of 98C at .46MPa.
Posted : 15/11/2016 7:34 pm
Wirlybird
(@wirlybird)
Check out ASA. Don't remember the temp though off hand. I use it to replace ABS for certain things.
Posted : 15/11/2016 8:33 pm
adrian.s2
(@adrian-s2)
Thanks,
I haven't tried ABS yet. I jumped from PLA to PETG as PETG seems a little more friendly than ABS regarding fumes etc.
It's definitely worth a consideration.
Posted : 15/11/2016 9:14 pm
Patrik Rosén
(@patrik-rosen)
Thanks,
High temp PLA would be my first choice to test if I needed that high deflection temp.
https://www.proto-pasta.com/products/high-temp-pla-v2-0
There are many brands offering this kind of PLA, and it can be threatened in the owen after print.
ASA is also a good choice, really easy to print, and with a heat deflection temp around 82 to 104 °C
Me on 3dhubs!
Me on MyMiniFactory!
Me on Instagram
3D Printing Live Feeds
Prusa MK2 Usergroup Slack Live Chat
Unofficial live chat by users for users.
Posted : 15/11/2016 9:28 pm
MrMik
(@mrmik)
I use Polymaker PC-max.
Posted : 15/11/2016 9:33 pm
SteveDunlap13
(@stevedunlap13)
I've used Nylon 680 from filaments.ca before. Printed parts that went into an autoclaver (sterilization) for a medical lab. Autoclaving reaches about 120 C - steam, etc. No deformations. Quite happy. This of course only on the MK2. Bed 80; Extruder 250; Default printing speed in S3D about 40mm/s. No cooling.
https://filaments.ca/collections/1-75mm-3d-filaments/products/nylon-680-fda-natural-1-75mm?variant=1327635152
Hope that helps.
Build to perform. Architect to evolve.
Posted : 15/11/2016 11:37 pm
Omikron
(@omikron)
Thanks,
I have found that high quality ABS generally doesn't produce noticeable fumes. I get mine from allproffesional3d.com.
Posted : 16/11/2016 12:01 am
Patrik Rosén
(@patrik-rosen)
Hope that helps.
Are you printing directly onto the bed or are you using blue tape or something?
Me on 3dhubs!
Me on Instagram
Posted : 16/11/2016 7:25 am
adrian.s2
(@adrian-s2)
Thanks all,
Some great ideas there. One more question, are any of the above food safe?
I know that PETG clear is classed as food safe. I think that Nylon is also.
Just a thought as I suspect that ABS may not be.
Posted : 16/11/2016 9:18 am
adrian.s2
(@adrian-s2)
Hope that helps.
Very interesting.
I've looked at Nylon before but you hear so many horror stories about getting it to print OK that I have avoided it.
Your print settings sound very straightforward so this may be an option to go for.
Thanks.
Posted : 16/11/2016 9:24 am
SteveDunlap13
(@stevedunlap13)
Depending on the part I may use glue to ensure it stays in place.
Posted : 16/11/2016 9:36 pm
JohnOCFII
(@johnocfii)
Similar to Patrik's recommendation, I'd suggest looking at a high-strength, high-temperature PLA such as MakerGeeks Raptor PLA. If you bake the item for 15 minutes after printing, it should withstand temperatures up to 125C. It is PLA, so it has all the easy printing characteristics of PLA.
http://www.makergeeks.com/histrength-17.html
I'm not sure how cost effective the shipping is to the UK from this U.S. based manufacturer.
John
Posted : 19/11/2016 4:16 am
Norman F
(@norman-f)
Taulman has a filament called "BluPrint" that they claim is ok to leave in boiling water for up to five hours. I hope it is not a nylon because I ordered a spool yesterday and I just saw that nylon does not stick well to PEI.
Posted : 19/11/2016 8:06 pm
adrian.s2
(@adrian-s2)
John
Thanks for that. I wasn't aware of Raptor PLA.
Definitely worth a look.
Posted : 20/11/2016 3:50 pm
valent.t
(@valent-t)
Thanks in advance.
So you bought original E3D V6 that is all metal? I don't see that as an option for 1.75mm filament. Please explain which model did you buy exactly and where, I also need high temperature printing and would like to also replace current E3D with full metal one.
Posted : 28/11/2016 9:03 pm
JohnOCFII
(@johnocfii)
[quote="valent.t"
So you bought original E3D V6 that is all metal? I don't see that as an option for 1.75mm filament. Please explain which model did you buy exactly and where, I also need high temperature printing and would like to also replace current E3D with full metal one.[/quote]
I believe that E3D considers the E3D V6 to be an all metal hot-end, even though there is PTFE tube in it. Their article states it can print up to 400C (with a different thermistor).
http://e3d-online.com/E3D-v6/Full-Kit/v6-1.75mm-Universal
Posted : 28/11/2016 10:24 pm
JohnOCFII
(@johnocfii)
Posted : 28/11/2016 10:27 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Yes, on the V6 the "hot end" is all metal; the PTFE stops in the cool end of the extruder, with a stainless steel heat break in between the tube and nozzle. The Lite6 does not have the stainless heat break and the PTFE tube goes further down towards the nozzle.
Peter
Posted : 29/11/2016 8:25 am
