Here are my settings for printing Sainsmart Flexible TPU
OldCoder
(@oldcoder)
Here are my settings for printing Sainsmart Flexible TPU filament on the MK2
# generated by Slic3r 1.31.6-prusa3d-win64 on Mon Dec 19 18:33:33 2016
bed_temperature = 70
bridge_fan_speed = 100
cooling = 1
disable_fan_first_layers = 1
extrusion_multiplier = 1.03
fan_always_on = 1
fan_below_layer_time = 100
filament_colour = #000000
filament_diameter = 1.75
filament_max_volumetric_speed = 0
filament_notes = "List of materials tested with Sainsmart TPU print settings for MK2:\n\nSainSmart 1.75mm Flexible TPU 3D Printers Filament - 1kg Spool (2.2 lbs), Black"
filament_settings_id =
first_layer_bed_temperature = 70
first_layer_temperature = 225
max_fan_speed = 100
min_fan_speed = 85
min_print_speed = 15
slowdown_below_layer_time = 25
temperature = 220
Chris Shaker
Posted : 24/12/2016 7:46 pm
Re: Here are my settings for printing Sainsmart Flexible TPU
Hi Chris,
where do you get your Sainsmart TPU from?
I got some, from sainsmart, ages ago, it was marketed as 1KG, filament, but on arrival the gross weight was 980 grams, (Net 800 grams...)
I have been looking for more black TPU filment and it seems difficult to locate at reasonable prices.
do you use talcum powder to reduce adhesion to the heated bed?
I had a couple of Near Misses, where the prints seemed impossible to remove from the heated bed...
now I write on the sides of the reel, to remind me to use Talc...
I got two reels of TPU from another supplier, and both reels were broken, internally, I noticed one when I opened the packing to use it... and got a reduced price for the roll... I checked the other, which seemed OK in the vacuum packing, but later when I opened it, the reel was being held tight by the vacuum...
this was a bit upsetting...
so I now have two whole reels of TPU to re spool, when I can find the time. and inclination. (Neither is black...)
p.s. I have two rolls from Sainsmart, Black, nearly finished, and transparent blue, both print well, and both reels are holding together nicely... 🙂
Regards Joan
Posted : 25/12/2016 1:06 am
Cacciola
(@cacciola)
Hey, thanks! I Tried your settings and they worked great!
Posted : 06/03/2017 2:26 pm
WhiteDragonD
(@whitedragond)
Did you select 0.15 Optimal in the Print Settings and modify anything in the Printer Settings?
I'm getting ready to print with some TPU For testing and was hoping you could tell me what you found out is best!
Posted : 04/04/2017 11:54 pm
OldCoder
(@oldcoder)
I don't remember what print quality I used to print it.
I do remember that the feed gear alignment with the teflon feed hole is critical to success!
I got the TPU from Amazon.com
Thank you for the talcum powder idea! Had not thought of that.
Chris
Posted : 27/04/2017 7:33 pm
magicman
(@magicman)
greetings friends!
TPU is amazingly easy to remove from PEI. i print in TPU frequently and never use glue stick or talcum powder.
the secret is to print directly on the PEI, and when the print is done, pour a small puddle of rubbing alcohol at the base of the print. you must pour enough alcohol so that it forms a standing puddle around at least part of the print. i usually pour some on and then spread the alcohol around the base of the print with my finger. then, with your fingernail or a spatula device, lift up a small edge of the print, starting in an area that's wet with the rubbing alcohol. the rubbing alcohol will begin to wick underneath the print, at which point you should be able to peel the print off the PEI with two fingers, using minimal force. if the TPU begins to stick to the PEI while peeling, simply pour more alcohol under the print in the area that's still in contact with the PEI.
the key is to keep the base of the print wet with rubbing alcohol when you peel the print off. this technique will work regardless of whether the print is warm or cold; the print will come off faster if it's still warm, slower if it's cold. ninjaflex will stick more than the harder TPUs, but will still peel off fairly easily.
Posted : 01/09/2017 7:59 pm
JMAC
 JMAC
(@jmac)
These settings worked for me too, except for second layer. Used 210 degrees.
I also started filament insertion by holding filament lever slightly open to allow feed. This keeps spring tension to my PLA setting for later. Dusted with talc, per Maxim suggestion, and raised "Live adjust Z" about 0.1 to allow first layer stick. Ran at 40% speed, using LCD knob.
I ended up with decent print, first time.
Posted : 01/09/2017 8:13 pm
Screwyluie
(@screwyluie)
230/60c with the fan at 50% printing at 25mm/s printed a cellphone case (thin walls and bridging) great. stringing was an issue I need to work on retraction, but otherwise it printed perfect.
Posted : 08/09/2017 9:26 pm
John U
(@john-u)
I like the look of those anti vibration feet. Do they work well and if so where can I find a model ? Thanks.
Posted : 07/01/2018 8:16 pm
rob
 rob
(@rob-15)
Sunlu TPU settings
I recently purchased a reel of SUNLU TPU. Sunlu seems to be a new filament vendor on the scene. I had problems with the extruder temperature and the cooling fan. I made the following changes to get a perfect print. Oh BTW the print stuck to the heatbed and was difficult to remove, maybe because there was a large surface area, but even the skirt was difficult to remove.
Filament Temp: 227 C to 230 C for all layers
No Cooling
Bridge cooling 50% if you want to chance it.
Bed temp 70 C then 65 C or lower
Here is the SLIC3r INI file:
# generated by Slic3r Prusa Edition 1.40.1+win64 on 2018-09-02 at 15:56:27
avoid_crossing_perimeters = 0
bed_shape = 0x0,250x0,250x210,0x210
bed_temperature = 65
before_layer_gcode = ;BEFORE_LAYER_CHANGE\nG92 E0.0\n;[layer_z]\n\n
between_objects_gcode =
bottom_solid_layers = 5
bridge_acceleration = 1000
bridge_angle = 0
bridge_fan_speed = 40
bridge_flow_ratio = 0.8
bridge_speed = 20
brim_width = 0
clip_multipart_objects = 1
complete_objects = 0
cooling = 0
cooling_tube_length = 5
cooling_tube_retraction = 91.5
default_acceleration = 1000
default_filament_profile = "Prusa PLA"
default_print_profile = 0.15mm OPTIMAL
deretract_speed = 0
disable_fan_first_layers = 4
dont_support_bridges = 1
duplicate_distance = 6
elefant_foot_compensation = 0
end_filament_gcode = "; Filament-specific end gcode"
end_gcode = G4 ; wait\nM104 S0 ; turn off temperature\nM140 S0 ; turn off heatbed\nM107 ; turn off fan\n{if layer_z < max_print_height}G1 Z{z_offset+min(layer_z+30, max_print_height)}{endif} ; Move print head up\nG1 X0 Y200; home X axis\nM84 ; disable motors
ensure_vertical_shell_thickness = 1
external_fill_pattern = rectilinear
external_perimeter_extrusion_width = 0.45
external_perimeter_speed = 40
external_perimeters_first = 0
extra_perimeters = 0
extruder_clearance_height = 20
extruder_clearance_radius = 20
extruder_colour = #FFFF00
extruder_offset = 0x0
extrusion_axis = E
fan_always_on = 0
filament_colour = #FF3232
filament_cost = 0
filament_density = 0
filament_loading_speed = 28
filament_notes = "List of materials tested with Sainsmart TPU print settings for MK2:\\n\\nSainSmart 1.75mm \n\nDas Filament\nEsun PLA\nEUMAKERS PLA\nFiberlogy HD-PLA\nFillamentum PLA\nFloreon3D\nHatchbox PLA\nPlasty Mladeč PLA\nPrimavalue PLA\nProto pasta Matte Fiber\nVerbatim PLA\nVerbatim BVOH"
filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6"
filament_settings_id = ""
filament_soluble = 0
filament_toolchange_delay = 0
filament_type = PLA
filament_unloading_speed = 90
fill_angle = 45
fill_density = 20%
fill_pattern = cubic
first_layer_acceleration = 1000
first_layer_extrusion_width = 0.42
first_layer_height = 0.2
first_layer_speed = 30
first_layer_temperature = 227
gap_fill_speed = 40
gcode_comments = 0
gcode_flavor = marlin
infill_acceleration = 2000
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 0.45
infill_first = 0
infill_only_where_needed = 0
infill_overlap = 25%
infill_speed = 60
inherits =
interface_shells = 0
layer_gcode = ;AFTER_LAYER_CHANGE\n;[layer_z]
layer_height = 0.2
max_fan_speed = 50
max_layer_height = 0.25
max_print_height = 200
max_print_speed = 100
max_volumetric_extrusion_rate_slope_negative = 0
max_volumetric_extrusion_rate_slope_positive = 0
min_fan_speed = 40
min_layer_height = 0.07
min_skirt_length = 4
notes =
nozzle_diameter = 0.4
octoprint_apikey =
octoprint_cafile =
octoprint_host =
only_retract_when_crossing_perimeters = 0
ooze_prevention = 0
output_filename_format = [input_filename_base].gcode
overhangs = 0
parking_pos_retraction = 92
perimeter_acceleration = 800
perimeter_extruder = 1
perimeter_speed = 50
perimeters = 2
post_process =
print_settings_id =
printer_model = MK2S
printer_notes = Don't remove the following keywords! These keywords are used in the "compatible printer" condition of the print and filament profiles to link the particular print and filament profiles to this printer profile.\nPRINTER_VENDOR_PRUSA3D\nPRINTER_MODEL_MK2\n
printer_settings_id =
printer_variant = 0.4
printer_vendor =
raft_layers = 0
resolution = 0
retract_before_travel = 1
retract_before_wipe = 0%
retract_layer_change = 1
retract_length = 0.8
retract_length_toolchange = 4
retract_lift = 0.6
retract_lift_above = 0
retract_lift_below = 199
retract_restart_extra = 0
retract_restart_extra_toolchange = 0
retract_speed = 35
seam_position = nearest
serial_port =
serial_speed = 250000
single_extruder_multi_material = 0
skirt_distance = 2
skirt_height = 1
skirts = 1
slowdown_below_layer_time = 20
small_perimeter_speed = 25
solid_infill_below_area = 0
solid_infill_every_layers = 0
solid_infill_extruder = 1
solid_infill_extrusion_width = 0.45
solid_infill_speed = 50
spiral_vase = 0
standby_temperature_delta = -5
start_filament_gcode = "M900 K{if printer_notes=~/.*PRINTER_HAS_BOWDEN.*/}200{else}30{endif}; Filament gcode"
start_gcode = M115 U3.1.0 ; tell printer latest fw version\nM201 X9000 Y9000 Z500 E10000 ; sets maximum accelerations, mm/sec^2\nM203 X500 Y500 Z12 E120 ; sets maximum feedrates, mm/sec\nM204 S1500 T1500 ; sets acceleration (S) and retract acceleration (T)\nM205 X10 Y10 Z0.2 E2.5 ; sets the jerk limits, mm/sec\nM205 S0 T0 ; sets the minimum extruding and travel feed rate, mm/sec\nM83 ; extruder relative mode\nM104 S[first_layer_temperature] ; set extruder temp\nM140 S[first_layer_bed_temperature] ; set bed temp\nM190 S[first_layer_bed_temperature] ; wait for bed temp\nM109 S[first_layer_temperature] ; wait for extruder temp\nG28 W ; home all without mesh bed level\nG80 ; mesh bed leveling\nG1 Y-3.0 F1000.0 ; go outside print area\nG92 E0.0\nG1 X60.0 E9.0 F1000.0 ; intro line\nG1 X100.0 E12.5 F1000.0 ; intro line\nG92 E0.0
support_material = 0
support_material_angle = 0
support_material_buildplate_only = 0
support_material_contact_distance = 0.15
support_material_enforce_layers = 0
support_material_extruder = 0
support_material_extrusion_width = 0.35
support_material_interface_contact_loops = 0
support_material_interface_extruder = 0
support_material_interface_layers = 2
support_material_interface_spacing = 0.2
support_material_interface_speed = 100%
support_material_pattern = rectilinear
support_material_spacing = 2
support_material_speed = 50
support_material_synchronize_layers = 0
support_material_threshold = 45
support_material_with_sheath = 0
support_material_xy_spacing = 60%
temperature = 227
thin_walls = 0
threads = 8
toolchange_gcode =
top_infill_extrusion_width = 0.45
top_solid_infill_speed = 40
top_solid_layers = 7
travel_speed = 180
use_firmware_retraction = 0
use_relative_e_distances = 1
use_volumetric_e = 0
variable_layer_height = 1
wipe = 1
wipe_tower = 1
wipe_tower_bridging = 10
wipe_tower_rotation_angle = 0
wipe_tower_width = 60
wipe_tower_x = 180
wipe_tower_y = 140
wiping_volumes_extruders = 70,70
wiping_volumes_matrix = 0
xy_size_compensation = 0
z_offset = 0
Posted : 03/09/2018 4:40 pm
jared.j4
(@jared-j4)
How do I get these settings into the slicer?
Posted : 29/01/2019 5:03 am
adam.h16
(@adam-h16)
Settings working great..just save the file as a blabla.ini na load config in slicer from the file menu
Posted : 12/02/2019 6:27 am
