Re: First print layer debugging
I would say:
- Live adjust Z should be more negative (-50 or -100). On my prints you should hardly say the pattern used as I tend to print the first layer squishy for high reliability but not all people do that.
- Decrease first layer speed to 30 or 20 mm/s. You shouldn't have to be in hurry for the first layer. And that layer is of big importance for many prints.
You pattern is not the easiest to print as first layer but you should have a perfect one.
Napsal : 08/03/2018 5:36 pm
Napsal : 09/03/2018 3:32 am
