Cura Starts prints at 0,0
I have tried to print these files for quite some time and every time I start printing the printer goes over to 0,0 and tries to print all of the object off the build plate.
First I am using Cura because I don't like the supports from PE Slic3r. I have other files that come out of Cura and print in the middle of the build plate.
Don't know how to share the Gcode from these so if you could help me figure this out I would appreciate it.
I run both through Pronterface and then export the relocated part in the gcode plater and it still fails to print on the build plate.
Not sure exactly what words are the correct ones since I am new to 3D printing.
Posted : 23/01/2017 10:40 am
