colorprint problems
I never had any problems with colorprint since today. I've upgraded to 1.7.7 drivers version today and after slicing my print with slic3r as usual with colorprint activated, I send it to colorprint (Something has changed also here because now I can change between multimaterial or standard.) I choose standard and set the heights where colorchange will occur. Then I download my new Gcode.
When I print it, before printing and just after calibration, it asks me to change filament 😯
I tried a new print with 2 color changing, and the printer asks me to change filament two times before starting to print and just after calibration 😯
Is there a new way to use colorprint ?
My youtube channel about the Prusa I3 MK2 https://www.youtube.com/channel/UCz-zQZcKcvEDdd9C9hOKYWg
Re: colorprint problems
By analysing the Gcode produced with colorprint, the command M600 was just after calibration (once for my first print and twice for the second).
Finally I added the M600 command by hand with a text editor and I don't use colorprint anymore. This is done very quickly using the search command in wordpad for example. 😀
