[Closed] Buildplate damaged by PETG
Page 1 / 2
NotSure
(@notsure-3)
Hello,
I had a problem with removing a PETG print from the buildplate. It ripped a little bit out of the surface. Now I cannot use this side of the plate anymore. Is there any technique to avoid this? The Buildplates are quite expensive. I have only got the printer since a few weeks. Replacing it constantly would not be so nice. Any tips?
Thanks
Regards
Posted : 12/01/2020 6:40 pm
Lichtjaeger
(@lichtjaeger)
RE: Buildplate damaged by PETG
Powder-coated or foiled?
The powder-coded plate didn't need special preparation. If you have the foiled plate, you should give the plate a wipe with window cleaner (no ammonia) before printing with PETG. It will slightly reduce adhesion.
Also, it is way more easy to remove the object from the plate after cooldown.
Posted : 12/01/2020 7:19 pm
NotSure
(@notsure-3)
Thanks for the reply and the tip with windowcleaner. Maybe I did take the print off to soon :-(. It looks like a foil piece came of. I was not aware there are two versions of the smooth one. Or did you mean the powedered one is the one with the structure?
Posted : 12/01/2020 8:34 pm
@tech
Yes, the powder coatet is the textured one and more stable as the foiled smooth sheet. You should only remove printparts after the bed was cooling down to roomtemp.
The smooth sheet you can temporarily repair:
or change the whole foil (have fun 😎):
Posted : 12/01/2020 8:48 pm
Lichtjaeger
(@lichtjaeger)
It's the first time you said something about the type of your plate. 😆
To answer your question: At the moment, Prusa only sells smooth foiled plates and textured powder-coated plates. Both are PEI surfaces.
For some time, they also did sell smooth powder coated sheets but they are not available at the moment, because they working on the formula.
Other companies also sell complete plates and/or foils of different types and materials.
Posted : 12/01/2020 8:49 pm
Posted by: @tech
At the time the Mk3 was originally announced at the end of 2017, Prusa intended to sell smooth and textured powder-coated PEI sheets. These have the "baked on" finish which is supposed to be more durable. It was quickly apparent they were having production issues, and they withdrew the smooth powder-coated option. At present, the only powder-coated option is the textured sheet, although Prusa has hinted that the smooth powder-coated option may return.
The older option is the smooth PEI sticker, sold as separate sheets, or pre-applied to a spring steel sheet. You can (with a bit of patience and elbow grease) replace the PEI sticker sheet. The Prusa PEI is very nice, but the BuildTak PEI sheets use adhesive that is much easier to replace in the future, although it is a bit thicker and will require a separate Live-Z calibration as do the powder-coated sheets.
I was able to temporarily repair my damaged PEI sticker with a bit of blue tape until I got around to replacing it. Not perfect, but usable. Here's my original smooth PEI stickered spring steel sheet showing the battle damage from trying high-temp PETG at 270C, the blue tape patch job, and the same high-temp stuff after printing with MagiGoo to improve separation.
Here's that same spring steel sheet with the Prusa PEI sticker replacement. Note that these sheets really like to corrode, so it looks ugly but the PEI surface is as smooth as the original. This is my designated "sticky stuff" sheet now.
Posted : 12/01/2020 10:14 pm
rmm200
(@rmm200)
Before you yank on a part hard enough to damage the surface - stick the plate in your freezer for an hour.
That will help.
Posted : 12/01/2020 10:27 pm
I had this problem with PETG and ABS.  I bought the following plate:
FYSETC Upgrade 3D Printing Build Surface
I print ABS and PETG on this and comes right off with cooling.
Posted : 13/01/2020 2:02 am
@charles-h13
thanks for the link!
I'll give this one a try and ordered one for my MK3:
https://www.aliexpress.com/item/4000148828753.html?spm=a2g0s.9042311.0.0.72624c4dcqkrHz
Maybe a flop? will see...and report.
Posted : 13/01/2020 10:52 pm
NotSure
(@notsure-3)
Thanks a lot for all the tips!
Posted : 14/01/2020 3:43 pm
Posted by: @charles-h13
Just to give an update, I have printed for 4 months on this plate and the same ABS or PETG product 3-4 times a day.  I get good adhesion with instant release.  If you have over adhesion with a particular filament, I highly recommend it.
Posted : 14/01/2020 4:08 pm
Just to note that the linked sheet is not sized for the Mk3. Is this on a Mk3, Charles, or a different printer?
I can't seem to find that particular sheet in a Mk3 format. I have one of the "golden" textured clone sheets, and it's like printing on friction tape. Not at all like Prusa or TheKKIINNGG sheets.
Posted : 14/01/2020 5:58 pm
Posted by: @bobstro
You are correct.  It does printer differently.  This is black and not gold.  The gold is crap.
I have found it superior for hard to remove prints on the Prusa TXT sheets.
Posted : 14/01/2020 6:03 pm
rmm200
(@rmm200)
Also Charles - the one you linked specifies not recommended for ABS...
@robert-rmm200
I see that.  It is identical to the one I am using.  It works with ABS.
Posted : 14/01/2020 6:05 pm
rmm200
(@rmm200)
They must just be concerned about the high temps. Glad it works!
Posted : 14/01/2020 6:14 pm
prusanewuser
(@prusanewuser)
@charles-h13
Hi Charles, is it fully compatible with the i3 MK3? Will it fit? If so, how to attract it to the printer?
Posted : 31/03/2020 6:58 pm
@peter-c20
It fits and attaches to bed with the magnetic bed.
Posted : 31/03/2020 7:03 pm
prusanewuser
(@prusanewuser)
Excellent! Thanks.
Anybody knows what he meant by alcohol? Is Isopropanol 99% fine? Doesn't putting alcohol on heated object cause fire?
https://www.prusamk2.com/how-to-easily-remove-petg-3d-print-from-a-pei-hotbed/
Posted : 31/03/2020 7:05 pm
rmm200
(@rmm200)
Alcohol we use is normally IPA. That video just uses it as a lubricant, so any concentration would work.
For cleaning your sheet, you want 91% or better.
His bed was 80 degrees C, or quite a bit cooler than boiling water. No fire there.
Posted : 31/03/2020 7:18 pm
Page 1 / 2
