Any tips on printing .1 resolution
luc.e
(@luc-e)
Hi, just tried to print my first PLA .1 resolution object with the Prusa I3 plus but that wasn't a big success. A Thingiverse downloaded object sliced with Prusa3D Slic3r 1.75mm and correct PLA .1 settings didn't work.
Finally I did manage to print the demo "PLA_3DHubs_Marvin_100um_1H" one with success but had to try multiple times to get the bed level right.
Any tips someone?
Luc
Posted : 26/12/2015 5:46 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Any tips on printing .1 resolution
Hi Luc
I think that when slicing, you need to make the first layer at least 0.23mm. You could also try printing on a raft.
I have printed using 50 microns with PLA giving a quite smooth finish, but with standard firmware I think the above also applies.
Peter
Posted : 26/12/2015 9:31 pm
luc.e
(@luc-e)
Thanks again Peter. I'll give it a try.
Luc
Posted : 29/12/2015 4:25 pm
