What spare parts are good to have around for the MK3?
[Chiuso] What spare parts are good to have around for the MK3?
Pagina 2 / 2
Martin_au
(@martin_au)
Re: What spare parts are good to have around for the MK3?
Jon, That is the correct size PFTE tube. It is shipped from China and can take a while to arrive but if you need it now here is the one I bought from SPOOL3D https://spool3d.ca/ptfe-teflon-tube/
Errrr, shouldn't it be 2ID, 4mmOD. 3mmOD is going to be very thin walled and probably won't be clamped by the connectors at each end.
Postato : 09/01/2019 10:05 am
For inside the extruder the PTFE tube internal diameter needs to be less than 2mm, to reform the tip diameter on retraction, I think it's 1.85mm or 1.90mm
for the tube from the top of the extruder to the MMU2, and from the MMU2 to the filament reels I have been using 2.5mm internal diameter to reduce friction... the MMU2 / mk3 printer uses these tubes as guides rather than part of the extrusion process, so the internal diameter is not critical
Postato : 09/01/2019 3:14 pm
Pagina 2 / 2
