What is the best way to get rid of seams using Slic3r on the MK3?
I printed the following with mostly default Slic3r PE settings 0.20mm DRAFT, except for calibrated 1.04 EM and 5% grid infill.
The seams are very obvious and I would like reduce their appearance for a smoother looking print.
I tried playing with retraction distance, z-lift and speed and have less stringing than before (after testing with retraction-tester prints). But I still get those seams. I thought maybe their visibility will reduce at least!
What settings should I test out for this to work? Would Linear Advance solve this problem?
Posted : 27/02/2018 7:26 am
