[Closed] Spring sheet lifting during print !
Page 2 / 3
Shoey
(@shoey)
Re: Spring sheet lifting during print !
yea its not worth to make/ship enclosures, if you are having the money for a prusa and the inclination to own a printer, you are diy your enclosure for <30$ from ikea/plastic bins/Thermasheath
True but it really depends on what the enclosure entails, Ikea tables are cheap but like most Ikea stuff, they suck in quality and not everyone prefers them. And of course, nothing beats a cardboard box but still, not everyone prefers that. I still think there is a market for something official and decent, not to mention a little more thought than just covering the printer. Ambient temperature, sensors, designed around electronics, filters, lots of possibilities to make it more then just a box.
Posted : 12/12/2017 12:56 pm
Jason Foss
(@jason-foss)
Possibilities to make it more then just a box.
Hell, one of those collapsible canvas laundry hampers with a plastic window on one side would be a great cheap enclosure upgrade to the cardboard box 😉
Posted : 15/12/2017 10:40 pm
reid.b
(@reid-b)
I was wondering how foam board would work for an enclosure? Cheap, easy to construct, and easy to store if you made it fold-up.
Posted : 16/12/2017 6:04 am
Christopher Tilley
(@christopher-tilley)
Might insulate it too well. If it gets hotter than 38C in there print quality will suffer.
Posted : 16/12/2017 11:17 pm
Stitch
(@stitch)
Has anyone tried binder clips mine is lifting too on the spitfire mk xv1 wing print...
Posted : 03/01/2018 3:46 am
digibluh
(@digibluh)
Jesus, this is disappointing.... i guess it wasn't tested on large prints.... 😮
Posted : 03/01/2018 7:56 am
maxx78
(@maxx78)
i use a 1mm galvanized steel sheet with a PEI foil for large prints.
Posted : 03/01/2018 10:46 am
Stitch
(@stitch)
I just had an idea I'm gonna print some slotted clips to go on the corners so it doesn't lift 🙂
Posted : 04/01/2018 5:14 am
JeffJordan
(@jeffjordan)
Member Moderator
i think if the pulling force is to strong, nothing would prevent a deformation of the print surface.... even if there was a stronger bond between sheet and heatbed. at least the heatbed (pcb) itself would bend as well.
@maximilian.r: ok, if you use an additional solid steel plate (1mm or even thicker), you can obviously withstand higher pulling forces.
and with the design of the MK3, this should be a decent solution.
Posted : 04/01/2018 12:20 pm
maxx78
(@maxx78)
i also have a 1.5 mm steel sheet but thats overkill. The issue is now more with the PEI sheet lifting from the steel.
i think a 1.5mm spring steel with PEI powder coat would be a perfect solution, maybe Prusa could this as an option... 😉
Posted : 05/01/2018 8:19 am
JeffJordan
(@jeffjordan)
Member Moderator
....I think a 1.5mm spring steel with PEI powder coat would be a perfect solution, maybe Prusa could this as an option... 😉
yeah, that would be cool. the design of the MK52 is explicitly to allow an easy change of the print surface. such a powder coated "monster" steel sheet, provided by prusa, really would be nice.
of course such an additional heat capacity needs to be compensated with a new, proper PID calibration for the heatbed.... otherwise you would end up in severe oscillations of temperature.
Posted : 05/01/2018 8:48 am
Protoncek
(@protoncek)
Just thinking loud... maybe increasing bed temperature would help? In any way instructions for bed temp says bigger model bigger ber temp.
Posted : 05/01/2018 9:56 am
maxx78
(@maxx78)
I think thats not really an issue, the system has more "thermal inertia" but the senor measures the temperature at the bed and not the surface of the steel. So i think you will end up with a sligthly less temperature on the surface.
I didn't see temperature fluctations / oscillations with the 1mm galvanized steel plate.
Personally i think the bed temp is not that critical, my PrinterBot (which i owned before my MK2 & MK3) had a relay for the heatbed with 5 °C oscillations and worked ok
But i have to adjust the Live Z Value as galvanized steel has different magnetic properties than spring steel 🙄
So an Live Z offset in the slicer wolud be great ! maybe as a preset like filament & Printer type.....
Posted : 05/01/2018 10:27 am
Peter
(@peter-12)
On the other hand a pid calibration is easy to do and doesn't take long, so why not do it just to be sure?
Posted : 05/01/2018 11:07 am
maxx78
(@maxx78)
2 Reasons:
1. I am lazy .... 😉
2. i switch between thin and thick sheets. And doing a PID after each change... see 1.
Why do i switch between sheets ? the 1mm plate is galvanized steel, not spring steel, so it is not so flexible, which is ok for big parts but not so nice for smaller stuff.
Posted : 05/01/2018 11:30 am
Protoncek
(@protoncek)
Isn't that already in Slic3r? Under "Printer settings" --> Z offset. Just make two printers there and different z offset for each.
Posted : 05/01/2018 11:58 am
maxx78
(@maxx78)
Uuups...... never saw that, thanks. 😳 😳
EDIT: that could also work as a solution for the different PID settings
Posted : 05/01/2018 12:13 pm
spark
(@spark)
That could also work as a solution for the different PID settings
Sorry off topic but confirming. So, let me get this straight.
  • Tune PID and Bed
  • Note M503 for M301 and M304
  • Insert custom M301 and/or M304 into Slic3r PE settings (save).
  • DO NOT M500 (overwrite value in EPPROM)
  • Reset printer after print session to restore default.
  • Corrections?
    MK2S kit owner since 8/15/2017
    Posted : 29/01/2018 5:09 am
    maxx78
    (@maxx78)
    Sounds ok...
    BTW: no PID tuning necessary for the thicker steel sheet. i do not see any fluctuations.
    Posted : 29/01/2018 3:16 pm
    avi.s
    (@avi-s)
    Out of curiosity as I don't have a MK3 yet, how thick is the spring steel plate? Thinking of maybe modifying one of my old printer to use such a plate if I can find one and glue a PEI sheet to it.
    Posted : 05/02/2018 4:18 pm
    Page 2 / 3
