Sneezle's MK3 ( noob printer)
Página 2 / 3
sneezle1980
(@sneezle1980)
Re: Sneezle's MK3 ( noob printer)
ok..... thanks i guess
Respondido : 15/03/2018 6:17 pm
try variable layer height to improve the curved detail especially the circular end where the contours are most visible
Thanks Joan,
i will try and do that...
maybe stupid Question but where can i find that option 😳 ?????
the variable layer height is accessible in the Slic3r Plater page, select the item then choose the layer editing tab... and you get windows like below, the two pictures shown indicate raw slicing,, with heavy contour lines and the about 66% of the same model set at a lower layer height which smooths the contour lines
Respondido : 16/03/2018 12:00 am
here are sample prints
[attachment=0]20180315_224441[1].jpg[/attachment]
the rear model is at original layer height
front left has a small section at lower layer height, and front right has about 66% smoothed with lower layer height!
Respondido : 16/03/2018 12:04 am
Respondido : 16/03/2018 12:06 am
sneezle1980
(@sneezle1980)
Thank you Joan, that helped a lot
Respondido : 16/03/2018 11:50 am
My pleasure. Ftge beauty of this feature is tgat you can apply it to sections of a model. Eg the wnd of tge handle and the finger holes of your sword where the contours are most visible
Respondido : 16/03/2018 11:54 am
sneezle1980
(@sneezle1980)
Since i'm in the medical field i descided to let my first big 30+ hour print be a anatomical skull.
First part is done and as suggested i used variable layer hight and slowed down external perimeter.
This part was printed:
With 10% infill and no brim or support
I think it turned out good, one layershift at end of print (teeth) but i can clean that up fine.
Any comments or suggestions are always welcome
Now printing top of the skull and the lower jaw
Respondido : 22/03/2018 10:03 am
gary.b
(@gary-b)
I like it. Good job.
MK2S & Mk3 my mini farm is alive 😆
Respondido : 22/03/2018 3:14 pm
sneezle1980
(@sneezle1980)
Thanks
Respondido : 23/03/2018 10:02 am
sneezle1980
(@sneezle1980)
Here are some of my latest finished prints all
is printed on mk3 apart from black rod where skull sits on. Printed with 20%infill and 0.15 layerheight
Respondido : 26/03/2018 2:32 pm
sneezle1980
(@sneezle1980)
So im still not completely happy with printing results, so if you guys on this forum could give some suggestions.... It would be appriciated.
This is 20 mm test cube, printed stock through slic3r PE on the stock 0.15mm optimal MK3 setting.
Respondido : 27/03/2018 6:59 pm
sneezle1980
(@sneezle1980)
Respondido : 27/03/2018 7:00 pm
sneezle1980
(@sneezle1980)
anyone ???? 😥
Respondido : 28/03/2018 9:30 pm
llj3663
(@llj3663)
by Sneezle » Wed Mar 28, 2018 7:30 pm
anyone ????
I didn't read through the whole thread but do you know what version printed parts you have? Specifically x-axis ends and z-axis ends?
Respondido : 28/03/2018 10:01 pm
HeySideburns
(@heysideburns)
I see those defects in every calibration cube i see posted here (including mine). It happens at the start/end of the layers. To confirm, use the setting that moves the seam to the back. The corners will look better, but the seam will still be ugly. I had marginal success with cura, but I’ve given up for now. I’m waiting for whatever fixes they are working on for the extrusion inconsistency before I waste more time on it.
Respondido : 29/03/2018 12:43 am
chris3030
(@chris3030)
I didn't see it mentioned, but could you tell us where you got the cool green cable wraps?
Respondido : 29/03/2018 2:08 am
Pascal.he3
(@pascal-he3)
Hi Sneezle,
can you let me know how the polymaker polybox works for you when you get it.
And also where can I buy the green cable wraps? My printer was ordered 18-01 and is now in transit.....
--pascal
Respondido : 29/03/2018 9:08 pm
sneezle1980
(@sneezle1980)
Hi Sneezle,
--pascal
Polybox works fine for me so far. At this point, since i have not found a good spot to put it so i can run it straigh from the box to the mk3. Im using it as storage box to keep my filament controlled at the moment.
As for the cable sleeve its flexo PET. And i got it from a local online store www.vanoostvoorn.nl .
or you can buy it here: www.wirecare.com
Hope it helps 😀
Respondido : 30/03/2018 5:30 pm
Página 2 / 3
