[Geschlossen] Selftest - X Axis Length
Seite 3 / 3
michael.f44
(@michael-f44)
Re: Selftest - X Axis Length
My printer had been working great and then I had issues with the prints not sticking to the bed and some layer shift issues. So I decided to go through the setup wizard again and got the X Axis Length error.
When my extruder head goes all the way to the left is where it seems to fail. If I manually move it that way it sort of moves all the way to the left and then when I let it go it rebounds to the right. From what looks like it's a belt issue with the gear. Has anyone else encountered and resolved this?
Veröffentlicht : 14/01/2019 6:49 am
Stilgar
(@stilgar)
RE: Selftest - X Axis Length
Posted by: @ian-w7
In Step 35 "Mounting the X-carriage-back"(5. E-axis assembly) I apparently tightend the 2 screw on the top to much, as soon as I losend them the Selftest - X Axis Length worked.
I love you ian! You solved my issue too!
For Mk3S is the chapter 5 E-axis assembly - Step 61 X-Carriage-back assembly.
In addition, I think I also understand why. The armor tightened too much the 2 rods.
So the carriage was unable to go back well from its run.
Thank You
Veröffentlicht : 19/01/2020 3:40 pm
theoforus
(@theoforus)
Sorry, but this did not helped in my situation. Any suggestions??
The selftest just stops in the middle of the x-axis.
There is always hope!
Veröffentlicht : 08/04/2020 12:38 pm
theoforus
(@theoforus)
@tobias-b
Thank you! This solved my problem. Now it went trough the selftest without getting error about the x-axis lenght.
Veröffentlicht : 08/04/2020 1:35 pm
Seite 3 / 3
