[Cerrado] Reinforced 3 bolt Y axis motor mount
Página 2 / 2
david04
(@david04)
Re: Reinforced 3 bolt Y axis motor mount
Roger that!
I have been following the instructions and making sure the elements move somewhat freely along the y and x axis, as with the z it is more difficult to accomplish. Also, I used some Mobil 1 to lube up the bearings, which resulted in much smoother rolling along the rails.
Thank you William and Joan for the welcome!
P.S. > Attached is the aforementioned "fix" until I can print the new mount.
Respondido : 18/10/2018 2:58 pm
Patrick McNamara
(@patrick-mcnamara)
Looks entirely serviceable. 🙂 The big question is, once you get things together and the printer working well enough to print a replacement mount, is it going to bug you enough that you are willing to take the printer apart and redo all the leveling? Luckily the Y axis is the easiest on which to work.
Respondido : 18/10/2018 4:47 pm
david04
(@david04)
That was entirely my train of thought; given I am a bit of a perfectionist, I shall. I do see your guys's point with regards to it slightly wobbling around.
Thank you for everything 🙂
Respondido : 19/10/2018 2:44 pm
Patrick McNamara
(@patrick-mcnamara)
I suffer from that problem as well. 🙂 Though it does seem to have been tempered a bit with age/experience... My solution is a second printer. 😀 That way, I can tinker on one an not be without the ability to print.
Respondido : 20/10/2018 4:08 pm
david04
(@david04)
I can't seem to shake it off. The other day I made a bed frame that was slightly too wide and I had to disassemble it just to trim ~1' off every board. Then I was happy.
Yeah, I totally agree with the 2nd printer, but at the same time, I'd like to stay married.
Respondido : 22/10/2018 6:14 pm
Página 2 / 2
