Deutsch
  • English
  • Čeština
  • Deutsch
  • Español
  • Français
  • Italiano
  • Polski
Login
  • English forum
    • České fórum
    • Polskie forum
    • Forum Français
    • Forum Italiano
    • Foro Español
    • Deutsches Forum
  • Neueste Beiträge
  • Announcements
Foren
English forum
Original Prusa i3 MK3 & MK3S & MK3S+
Others (Archive)
pre heat error
[Geschlossen] pre heat error
Seite 1 / 2 Nächstes
    Letzter Beitrag
Graham
 Graham
(@graham-2)
pre heat error
Hi
Has any one else had this problem?
printing with PETG going well about 20 layers up and then i get pre heat error.
before we all start giving me many different ideas, its only been a few weeks since it was back at the factory for repair.
what is odd is that i can print pla
any thoughts
Log in to be able to post
Veröffentlicht : 10/02/2020 9:19 pm
Graham
 Graham
(@graham-2)
RE: pre heat error
just a update been playing and found that the next time i used petg i got thermal run away, this is getting crazy now.
last print it only happened when the fan came on.
will put a sock on it, do i need the fan on petg any way?
Veröffentlicht : 11/02/2020 9:52 am
RE: pre heat error
@graham25fox
Use a silicone sock an fanspeed between 35% and 50% for petg. Best results you will get with printing on the textured PEI sheet. If 50% causes too much stringing, increase to 70%.
Veröffentlicht : 21/02/2020 12:41 pm
Graham
 Graham
(@graham-2)
RE: pre heat error
@karl-herbert
Thanks for the reply.
i have run a sock for some time now, by accident i found to lower the cooling, not had error any more.
finding PETG qiute easy to print.
sounds interesting about the textured plate, may have to get one, one funny thing is i went to print PLA changed profile(not the plate)and found that it would not stick at all.
had to REALLY clean for it to stick, so a different plate may be a good idea then
Veröffentlicht : 21/02/2020 4:26 pm
RE: pre heat error
@graham25fox
Usually the smooth printing plate is better for PLA and the textured one is better for PETG. It's good to have both. The PrusaSlicer settings usually give good results. Important: Before you start printing, the plate should be cleaned with soap and water and free of grease/dust. Additionally wipe briefly with Isopropanol. Don't use Acetone or similar.
Veröffentlicht : 21/02/2020 4:58 pm
Zoltan
 Zoltan
(@zoltan)
Mitglied Moderator
RE: pre heat error
Wnat is your room  temperature your pri ter is put?
What was the reason your printer for repair?
One possibility would be to run PID autotuning with temperature for PETG 240°C or ASA 250°C.
Veröffentlicht : 21/02/2020 5:01 pm
Graham
 Graham
(@graham-2)
RE: pre heat error
@zoltan
the reason for repair was i was getting constant MIN TEMP ERROR, I must say before you ask the printer was in a alcove that was always above 20c.
when the printer came back the fault was found to be bad/ missing part. I had the printer built at the factory so i would not have any problems!
i know they changed the thermistor, but have no clue as what else was done, anyway all working good now thanks for all the help
most of my printing is in PLA
Veröffentlicht : 21/02/2020 8:58 pm
Zoltan
 Zoltan
(@zoltan)
Mitglied Moderator
RE: pre heat error
@graham25fox
So I am glad, your printer works fine. Happy printing !!! 👍
Veröffentlicht : 22/02/2020 8:12 am
theoforus
 theoforus
(@theoforus)
RE: pre heat error
I had a thermal runaway error after having a door standing open a while during a print.
Now I am trying to do a new print, but the nozzle won´t heat up at all. I have tried to blow with a hair dryer and the temp rised so the termistor is not the problem. I have checked the connection on the board and reflashed the firmware, but nothing has helped so far.
Any advice would be of great help.
There is always hope!
Veröffentlicht : 25/04/2020 9:53 pm
RE: pre heat error
@reidar
If the nozzle is no longer heating and the thermistor is OK, it is probably due to the heating cartridge. I would measure these times. The internal resistance should be approx. 14.4 ohm (24V / 40Watt).
Veröffentlicht : 25/04/2020 11:18 pm
Zoltan
 Zoltan
(@zoltan)
Mitglied Moderator
RE: pre heat error
@reidar
How old is your printer and what is your room temperature. During the last heating trial the temperature did not change at all?
Veröffentlicht : 26/04/2020 9:57 am
Peter M
 Peter M
(@peter-m)
RE: pre heat error
@graham25fox
Wash bed with dish soap, no alcohol, the a few prints with alcohol, then dish soap again.
Small objects or big flat objects always clean with dish soap.
And first layer should be 100% the it sticks better,
Both beds should work, and PLA sticks less on the powder coated, but should work.
Veröffentlicht : 26/04/2020 10:27 am
theoforus
 theoforus
(@theoforus)
RE: pre heat error
@karl-herbert
Thank you for taking the time to answer. I don´t know how to do that, but I have a multimeter. Could you send me a picture or something that could show me where I put the pins on the multimeter. Danke.
Veröffentlicht : 26/04/2020 10:36 am
theoforus
 theoforus
(@theoforus)
RE: pre heat error
@zoltan
Thank you Sir. The room temperature was 23 deg. Celcius, but I had a door open a while and I guessed that cooled down the nozzle too much.
The printer is one year.
Veröffentlicht : 26/04/2020 10:39 am
theoforus
 theoforus
(@theoforus)
RE: pre heat error
@zoltan
The nozzle showed a rise in temp when heating with a hairdryer, but I am not able to heat it with the PREHEAT function.
Veröffentlicht : 26/04/2020 10:40 am
Zoltan
 Zoltan
(@zoltan)
Mitglied Moderator
RE: pre heat error
@reidar
A question, did you buy it assembled or as a kit? Based on the answer would be our suggestion. The most safe would be to open the electronic box and unplug the heater and measure the resistance o  the cable plug.
Or start the preheating and try to the shake a bit with the cable leading to the head, it could be a broken cable as well due to often move , but this could happen when the printer alraedy passed couple miles of printing.
During preheat the bed started to heat up?
Veröffentlicht : 26/04/2020 10:52 am
RE: pre heat error
@reidar
to measure, switch off the printer and pull heating cartridge plug off the printerboard (unlock carefully). When measuring the resistance, the polarity does not matter.
Veröffentlicht : 26/04/2020 12:46 pm
theoforus
 theoforus
(@theoforus)
RE: pre heat error
@zoltan
I bought it assembled, but after that I have taken the extruder head apart and replaced the thermistor ´cuz I broke the cables during an attempt to clean the nozzle after a giant filament blooob on the nozzle/heater.
I will try to check the resistance.
The bed heats as it should.
Veröffentlicht : 26/04/2020 5:52 pm
theoforus
 theoforus
(@theoforus)
RE: pre heat error
@karl-herbert
Hello again. Test done. When setting the multimeter to 200ohm there was no response = 1
I guess that means I have to buy a new one? Any suggestions? I have seen some at aliexpress, but I can not say anything about the quality.
Tested some other heaters from an anet a8 that I have  and I got 3,2ohm and 4,7ohm on another one.
How much resistance should there be for this printer (mk3s 24v) ?
Veröffentlicht : 26/04/2020 8:17 pm
RE: pre heat error
@reidar
1 means a broken contact. The MK3 series should have 14.4 ohms:
24V = 1.667A * 14.4 ohms
24V * 1.667A = 40watts
The Aliexpress heater cartridge will work, but long delivery times (cheap but no support). Best qualitiy are the E3D ones. If you order from aliexpress you must order the 24V/40watts for the MK3 series. You can also use 24V/50watts.
I you would use the Anet 8 with 3.2 ohms you will overheat the system:
24V = 7.5A * 3.2 ohms
24V * 7.5A = 180watts
I would use max. a 50watts cartridge, maybe 55-60watts.
If you buy a new cartridge, I would order two, so you have one on reserve. Also a thermistor for the nozzle and the heating bed. These are wear parts that break sometimes.
Veröffentlicht : 26/04/2020 10:04 pm
  Alle Forumsthemen
  Vorheriges Thema
Nächstes Thema
  Forums-Statistiken
598 Foren
71.4 K Themen
501.5 K Beiträge
11 Online
82.4 K Mitglieder
Letzter Beitrag: When will alternate nozzles be available for purchase? Unser neuestes Mitglied: Tim Neueste Beiträge Ungelesene Beiträge Schlagwörter
Forum Icons: Das Forum enthält keine ungelesenen Beiträge Das Forum enthält ungelesene Beiträge
Themen-Icons: Unbeantwortet Beantwortet Aktiv Heiß Oben angepinnt Nicht genehmigt Gelöst Privat Geschlossen
