Pin outs for the filament sensor?
neil.e
(@neil-e)
Anyone have a diagram or info on what the four wires coming off the filament sensor map to? I'm looking at getting it hooked up to my Raspberry Pi that's running Octoprint so I can use one of the Octoprint filament plugins. In order to do that I need to know what the wires are 🙂 I assume one is power, one is ground, one is the signal, but what's the fourth, and which is which?
Thanks!
Postato : 24/03/2018 4:54 am
RH_Dreambox
(@rh_dreambox)
Re: Pin outs for the filament sensor?
Maybe this one can help you.
Postato : 24/03/2018 9:56 am
Peter
(@peter-12)
There was an earlier thread discussing the filament sensor, it maybe can provide some additional information. I think there is a link to the sensor spec sheet as well. https://shop.prusa3d.com/forum/original-prusa-i3-mk3-f30/filament-detector-overheating-t12849-s20.html#p59330
Postato : 24/03/2018 12:27 pm
neil.e
(@neil-e)
Thank you both for the tips!
Postato : 24/03/2018 3:23 pm
