New cooling solution I hope you like
Pagina 2 / 2
JLTX
 JLTX
(@jltx)
Re: New cooling solution I hope you like
I saw the latest design...
The path that the flow of air needs to take seems to long... How is the cooling on the right side?
Do you have any photos of test prints or something?
There are internal channel guides that partition the air. If you print you will see the set up. The air flows more or less equally from all sides. I will get some pictures. The benchy came out better than my last one with stock, but still not perfect.
Postato : 11/01/2018 2:27 pm
Impruve
(@impruve)
With the latest settings for Slic3r, and with S3D i can already get a perfect benchy using the stock shroud.
But i do have some models that clearly have cooling issues where i think they shouldnt have.
If i have the time i will print yours and test it out.
I also have to print a Shroud i designed to be similar to the MK2S one. I know it only has airflow on the front but from what i've been hearing that shroud was performing better than the MK3.
Postato : 11/01/2018 5:00 pm
Pagina 2 / 2
