my first MK3 part
JLTX
 JLTX
(@jltx)
my first MK3 part
I'm not a fan of the printer mounted spool holder (of any kind), so I go outboard. I still want the filament coming down from above so created this: https://www.thingiverse.com/thing:2727093
Publié : 22/12/2017 10:52 pm
Bigdogbro1
(@bigdogbro1)
Re: my first MK3 part
That is a clever idea. I will use it! I always thought that having 1kg spool of weight on the top frame would cause some flexing. 😀
MK3 Kit, Designed, built 4x4 CNC Plasma Cutting Table, Motorcycles Bigdogbro's Adventures
http://www.youtube.com/channel/UC5djrxBeeOKB9_6rHnn6G8A
Publié : 23/12/2017 2:03 am
JLTX
 JLTX
(@jltx)
one more: https://www.thingiverse.com/thing:2727489
I'm probably the only one using a Logitech webcam. But maybe you can find other uses.
Publié : 23/12/2017 5:07 am
tom.b6
(@tom-b6)
You're not the only one using a Logitech cam.
https://www.thingiverse.com/thing:2263707
Publié : 23/12/2017 12:49 pm
JLTX
 JLTX
(@jltx)
I updated this today. I added an extra piece to increase height if you are printing Z > 180mm to reduce angle. I forgot the MK3 input is a bit higher. I also tweaked the runner a bit to run smoother. Enjoy.
Publié : 23/12/2017 5:39 pm
