[Fermé] Loud rattling sound from PSU
Page 1 / 4
jettoblack
(@jettoblack)
The loudest source of noise (by far) on my MK3 is a rattle coming from the PSU during some print moves. I'm not referring to the clicking sound that occurs as the bed or hotend PWM heaters kick in. This rattle sounds like a loose screw or metal-on-metal vibration coming from inside the PSU. I shook it, but nothing came loose or fell out. I can't tell if it's coming from the PSU itself or the wiring components within the 3d printed cover.
Just wondering if anyone else has this issue before I dismount the PSU and try to pinpoint the source of the noise.
Thanks.
Publié : 08/12/2017 4:50 pm
maxx78
(@maxx78)
Re: Loud rattling sound from PSU
I have the same issue...during mesh leveling the isolation sheet in the psu rattles. If i tap the psu it also rattles slightly
Publié : 08/12/2017 7:21 pm
Impruve
(@impruve)
Did you guys check with support?
Publié : 09/12/2017 1:05 am
maxx78
(@maxx78)
I just did.
The guy in chat said it is not normal and he will check back with his colleagues.
here a video of the noise:
Publié : 09/12/2017 10:52 am
jettoblack
(@jettoblack)
Here's mine. I think mine is much worse than yours.
Edit: Sorry on second thought it is about the same as yours, I'm not trying to boast whose is worse. 😆
Publié : 09/12/2017 7:52 pm
Ron Hunt
(@ron-hunt)
I just finished my build.. and also have the same issue of a rattle inside the PSU. Oddly enough mine is loudest when tapping the Einsy board lol.. something about the vibration.
I hear it during moves while printing.. I'll need to contact support. I think its about half way down the supply.. sounds like a loose piece of metal rattling at just the right vibration. I'll have to contact support since I don't want to void warranty by opening it.
Ron
Publié : 11/12/2017 2:00 am
I'm no Filament Frenzy
(@im-no-filament-frenzy)
On the videos it sounds like case vibration rather than something inside rattling about. Try checking for loose screws on metal case cover or even squeeze the case together ( by hand ) to see if that is the issue
Publié : 11/12/2017 7:40 am
maxx78
(@maxx78)
nope, defintly inside the PSU. lose screws wa the first thing i checked. In the beginning i suspected the bearings or the Nut fromn the Z-axis
I removed it from the printer and gave it a tap and it rattles. and with the PSU not installed the rattle is gone.
I also checked the screws from the PSU, they were all tight.
There is a plastic sheet inside between the PCB and the case which i think is ratteling.
Publié : 11/12/2017 11:14 am
jweaver
(@jweaver)
Has no-one had the courage to open up the PSU and get to the source of the rattle.
I can't imagine that Prusa would hold this against you if you did.. If mine does this, I am just going to open the PSU and secure what is rattling, irrespective of warrantee.. At the end of the day, I cant' see they would ever know (or care) that I had opened it IF I needed something from them.
Edit: Now that i have writen then, I should say that I am not condoning anyone to do this.. Playing around inside PSUs can be dangerous as the caps still hold a charge even with mains removed.. So if you are inspired to do this, please make sure you know what you are doing and discharge the PSU before poking around inside.
Publié : 11/12/2017 4:49 pm
Ron Hunt
(@ron-hunt)
I have a case opened with Prusa on this.. I am avoiding opening it to figure out what’s wrong because it has “do not break” seals. Once/if they tell me to take a look; I will. It seems to work fine, but with fast x/y movements it really starts getting noisy.
They wanted a video of my issue which I sent them.. we shall see.
Ron
Publié : 11/12/2017 7:47 pm
maxx78
(@maxx78)
I would but to open the psu i would have redo the wiring....and i i have to until the caps are discharged and cannot play with my new toy 🙄
Publié : 11/12/2017 10:03 pm
rotarypower101
(@rotarypower101)
Ron
Hey Ron, on the topic of sounds, watching section 6 now, on the noisy Einsy ver B board is it possible the suspended cantilevered daughter board is the culprit causing the distinct vibration?
I can't think of anything else to attribute it to?
Have you pinpointed and resolved that noise?
Seems like anything oscillating like that would eventually fail from work hardening the pins, or even popping a pad after long enough?
Publié : 12/12/2017 2:25 am
john.n13
(@john-n13)
Take another look, I suggest...
Ron pinpointed the noise and identified it as coming from the power supply. It seemed as if a tap on the control box was exciting the frame and the PSU.
From what I could discern from the video there wasn't enough mass in the control box assembly itself to create or sustain that level of vibration.
Publié : 12/12/2017 2:53 am
Ron Hunt
(@ron-hunt)
the rattle is indeed from the PSU. It was odd; but tapping the control box just seemed to really trigger it. I know whatever it is; is about half way up.. and is inside 🙂
Still waiting on a response from support.
Ron
Publié : 13/12/2017 1:54 am
Nullzero
(@nullzero)
Just want to say, my PSU rattles as well. The machine would be so quiet if it wasn't for the rattle!
Publié : 13/12/2017 4:33 am
ScaleTheTrail
(@scalethetrail)
Looks like its vibrations between the frame and the PSU casing to me, but cannot say for certain based on a few youtube clips. Will check my own printer when it arrives(hopefully in a few days).
Reminds me of how 90% of the noise from modern refrigerators usually come from loose waterlines on the back vibrating due to the compressor working..
Publié : 14/12/2017 3:34 pm
Ron
 Ron
(@ron-8)
Hi All,
just received the BLACK box... 🙂
not building right away, but checked to separate PSU for the rattle.
and yes it is in the PSU itself
looking at the inside trough the mesh.
is see a capacitor (i believe) with carbon filters or something like that and after shaking and trying to hold the pieces with a long sticky...
it looks the source of the rattle.
@josefprusa
hope this helps
regards and happy printing
Ron
Publié : 15/12/2017 2:30 pm
stephan.w
(@stephan-w)
Looks like we could 3d print some anti-rattling stick that locks in the cooling slots and holds down the rattling parts...
Publié : 15/12/2017 4:33 pm
Kai
 Kai
(@kai-2)
What about hot glue?
Normaly it is noncunductive and perfectly suitable to lock parts in postition.
But just as long as the temperatury does not raise to much.
nec aspera terrent
Publié : 15/12/2017 5:03 pm
Bigdogbro1
(@bigdogbro1)
Those beads are ferrite and I think are used for RFI suppression. They are normally placed over the radial leg of the component and then the component leads are bent to be soldered into the PCB. A dab of real 100% clear silicone adhesive can be placed on both sides to connect the ferrite bead to the component body (and to the PCB if needed) to help stop the vibration.
UNPLUG THE POWER CORD FROM THE POWER SUPPLY BEFORE STICKING ANYTHING INSIDE THE PSU!!!
I would use 100% clear silicone on a toothpick or other non-conductive stick so you don't short out the component leads to the case cover if you happen to touch the leads.
MK3 Kit, Designed, built 4x4 CNC Plasma Cutting Table, Motorcycles Bigdogbro's Adventures
http://www.youtube.com/channel/UC5djrxBeeOKB9_6rHnn6G8A
Publié : 15/12/2017 5:54 pm
Page 1 / 4
