I don't understand this Z-Live calibration
[Closed] I don't understand this Z-Live calibration
allhabibimashalla
(@allhabibimashalla)
Hello everyone,,
I ran through all of the calibrations and everything was good except the nozzle was rubbing the bed on location 2 (it rubbed some of the printed white text off of the bed). The machine still printed and I had the Z-Live set to -0.560. Tech support said I needed to drop the PINDA and run the calibration again, just make sure I didn't drop it too far. So I lowered it ever so slightly, reran the calibrations and no rubbing this time. Now the Z-Live setting for the first layer calibration is at -0.900 and the first layer looks bad, it still needs to go lower. I thought if the PINDA was lowered the Z-Live would get smaller not higher. I don't know what to do now. Any suggestions?
Thanks.
Posted : 25/11/2019 6:02 am
rmm200
(@rmm200)
RE: I don't understand this Z-Live calibration
First off, set the PINDA level like the construction manual shows. Drop the nozzle to a sheet of paper on the bed.
Loosen the PINDA and slip a piece of zip tie under it. Use that as the spacing. Tighten the PINDA mount - and don't change it.
Now read this and follow:
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/life-adjust-z-my-way/paged/1/
Closer you get to the bed, the more negative Z gets. Not smaller - more negative. Don't let the nozzle - ever - touch the bed.
It will no neither the nozzle or the bed any good.
Posted : 25/11/2019 6:12 am
