How to speed up print after start of Print
[Zamknięte] How to speed up print after start of Print
MikiCab
(@mikicab)
Hello Everyone.
I started a print at the highest quality of print in the slicer and am regretting it. I am 18 hours into a print and only at 30%. Quality looks unbelievable but probably don't need kind of quality for a battery holder lol.
I set the slicer for 0.05mm detail just to see what it would do but unfortunately it is taking forever.
Thanks.
Opublikowany : 31/12/2017 6:07 pm
Re: How to speed up print after start of Print
you can try dialing up the speed on the LCD just turn the knob and watch the 100% value change,
as the speed increases, so will the noise, but the quality will decrease
best wishes
Joan
Opublikowany : 31/12/2017 6:14 pm
MikiCab
(@mikicab)
best wishes
Joan
Thanks. I will give it a try. It already looks like an injection molded part so a little reduction in quality should not matter.
Opublikowany : 31/12/2017 6:23 pm
next time a greater layer height will print faster. for a battery case, 0.35mm layerheight will probably be adequate and provide a stronger model, printed in about 15% of the time.
Opublikowany : 31/12/2017 6:31 pm
MikiCab
(@mikicab)
I am still learning. Just got my first printer 1 week ago and have only printed 5 things so far. I am designing stuff on Fusion 360. Using Prusa Slicer and watching a lot of YouTube videos and reading am much stuff as possible online. Lot of information to digest. So far no failed prints from 4 PLA and one PETG prints. I have MakerGeeks and HobbyKing filament and both seem to work well so far.
Enjoying the experience and happy with my purchase.
Opublikowany : 31/12/2017 6:38 pm
yeah! your friends are likely to get fed up with your enthusiasm, (unless it helps them directly)
and then there is the... well my printer is always busy, so i need another... and another... and ....Bang goes the bank account!
Opublikowany : 31/12/2017 6:53 pm
joaquin.o3
(@joaquin-o3)
best wishes
Joan
Changing the printing velocity BEFORE the print is possible? Because I test a part with lower printing velocity and the result was good, but when I started to reduce the speed the printing was affected by the change in velocity, it was not a big deal but just to be sure if it can be done.
Opublikowany : 21/02/2019 9:28 pm
