					                		How to achieve more consistent prints? - Others (Archive)                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-others-archive/how-to-achieve-more-consistent-prints/</link>
                <lastBuildDate>Fri, 15 May 2026 11:23:01 +0000</lastBuildDate>
                        <title>Re: How to achieve more consistent prints?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-others-archive/how-to-achieve-more-consistent-prints/#post-74080</link>
                        <pubDate>Wed, 28 Mar 2018 05:34:55 +0000</pubDate>
                        <description><![CDATA[What filament are you using? This sounds like an example of under-extrusion.]]></description>
                        <content:encoded><![CDATA[<t>What filament are you using? This sounds like an example of under-extrusion.</t>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-others-archive/">Others (Archive)</category>                        <dc:creator>Kwaad2</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-others-archive/how-to-achieve-more-consistent-prints/#post-74080</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-others-archive/how-to-achieve-more-consistent-prints/#post-74064</link>
                        <pubDate>Wed, 28 Mar 2018 02:59:25 +0000</pubDate>
                        <description><![CDATA[Thank you, Ill do that!]]></description>
                        <content:encoded><![CDATA[<t>Thank you, Ill do that!</t>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-others-archive/">Others (Archive)</category>                        <dc:creator>jacob.c9</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-others-archive/how-to-achieve-more-consistent-prints/#post-74064</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-others-archive/how-to-achieve-more-consistent-prints/#post-74019</link>
                        <pubDate>Tue, 27 Mar 2018 22:12:29 +0000</pubDate>
                        <description><![CDATA[Check always each layer in the Sli3er preview. You can exactly see how many perimeters the printer will print.
For each model and filament you might need to adjust the sli3er settings. This ...]]></description>
                        <content:encoded><![CDATA[<t>Check always each layer in the Sli3er preview. You can exactly see how many perimeters the printer will print.<br/>
For each model and filament you might need to adjust the sli3er settings. This is something grow with more experience.<br/>
If you have a question to a specific model/example, feel free to post pics of this.</t>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-others-archive/">Others (Archive)</category>                        <dc:creator>Nikolai</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-others-archive/how-to-achieve-more-consistent-prints/#post-74019</guid>
                        <title>How to achieve more consistent prints?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-others-archive/how-to-achieve-more-consistent-prints/#post-74017</link>
                        <pubDate>Tue, 27 Mar 2018 21:35:21 +0000</pubDate>
                        <description><![CDATA[Problem: I have prints going great, but often I get a wall that prints thin on 1 or 2 different layers. It’s noticeable and it often breaks at those thin layers. I can see through those laye...]]></description>
                        <content:encoded><![CDATA[<t>Problem: I have prints going great, but often I get a wall that prints thin on 1 or 2 different layers. It’s noticeable and it often breaks at those thin layers. I can see through those layers. I’m trying to print 1 and 1.5 mm walls. <br/>
It’s frustrating because it typically happens 3/4 of the way through print job.<br/>
My print settings: I’m using slic3r and using preprogrammed settings (1.0 detailed). I’ve been printing at speed 190. I know it’s fast but the prints are great except the thin walls that occur more than I like.<br/>
Thank you in advance!</t>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-others-archive/how-to-achieve-more-consistent-prints/#post-74017</guid>
