Help! Mk3 lost it's marbles...
Really odd behavior...
I had just began a second run of the same item.
The bed was still warm from the prior run.
Upon starting, the unit went to the top of the z screws and began bed leveling! At the top!
I've tried everything,
Including;
Rebooting numerous times
Unplugging for 20 minutes
Re-flashing same firmware
Re-flashing December 30th firmware .143
Re-plugged all connections
Moved z axis to the bed by hand and tried to print again
Tried each calibration method
Moved the z axis in both directions using live z adjust (successful BTW)
Anyone have any ideas?
The z axis will only move up to its grinding end-stop except for live z adjust
Re: Help! Mk3 lost it's marbles...
Seems like the PINDA probe is stuck at the "ON" position. Contact the support.
Email sent...
I hear y'all have a chat feature...
Can't find it...
Where ya hiding it?
Hi Jonathan,
go look at the eShop page
https://shop.prusa3d.com/en/#_ga=2.247646471.12039957.1514842282-1753999109.1496655960
the chat should pop up at the right of the screen after a couple of seconds
I think some ad blockers also block the chat features of some web sites.
When someone asks you if you're a god, you say, "YES!"
