Re: For us MK2s -> upgraders: Plastic Parts?
Why comparing if all the info is in the readme?  https://github.com/prusa3d/Original-Pru  ... /README.md
We print everything in petg now except the fan shroud, but Abs-T will work for too.
While the above may be clear to some, exactly which part(s) is the fan shroud? I can make a pretty good guess but since there is no printable part named "fan shroud" (that I see) I could use a bit more clarity.
Which STL file(s) need to be printed with ABS?
Thanks
The part named "nozzle-fan" is a fan shroud, I think. I don't know if there is a technical difference between a nozzle and a shroud.
from what Prusa support explained, the extruder parts being black ABS is for the light transmission on the filament sensor. Black works best as it doesn't reflect any light towards the sensor.
How many different messages can they give?
Jospeh P stated in this forum that all parts is printed in PETg except for parts fan which is in ABS??
well I will now go off of what Mr. Prusa says vice what support wrote me. I just wish they would either say what the settings are or do make ready g-codes for everything. thanks for the reference.
