        Bed wire harness crashed with rear Y Axis Support
Posting this just to warn you guys that I got a serious crash because the Bed Wire Harness got caught by the orange support below the bed.
I think it damaged one of my X Axis bearings, because the wires bent under the bed making a lever and pushing it up against the X Axis. Now the printer is making a low rattling noise when it moves to the right.
The solution I found was to add another zip-tie to the wire harness to push it up and avoid anything below de heated bed (see picture).
You won't be able to open the access to the motherboard if you use this solution, or else, you have to cut the zip-tie. (not a big deal for me)
                            Posted : 06/02/2018 12:58 am
