Bed leveling issues
So i got a kit version of the MK3 I3
And there are a bunch of little issues that i cannot seem to get around.
First one, the PID sensors is irritating as F. It will set what it think is the correct Z on every print, and i ALWAYS have to adjust it while printing to get it to stick. Done multiple calibrations, and that helped a little but it is still off! Why cant it just be set one, and then be left alone ?
Second one is mesh leveling seems to be not working or totally off ?
it started on the left top corner. So that is where i made sure my Z is good.
Anyone else having issues like this?
Re: Bed leveling issues
My bed level correction doesn't seem to be doing anything at all either.
PID, I think you mean the PINDA sensor.
If it is properly calibrated (0.5 to 1 mm higher than the tip of the nozzle) then your Z-level should work.
What value do you have on Z-level now, and in what value area have you tested Z-level?
Or do you mean that the printer "loses the Z level value" to the next printout?
Can you try to add pictures again.
