Spool Adapter
I made a spool adapter for the spools I got from filamentinnovations.com,
one side of the spool has a larger hole and doesn't sit on my MK2 spool holder very well so I made an adapter for it thought I would share
If anyone wants to try it you can find it here
https://www.myminifactory.com/object/34163
Re: Spool Adapter
I use a piece of plumbing pipe through the middle of the roll, resting on the two support nodules for the same reason
Re: Spool Adapter
I did the same thing at first but I dint like the way it looked so I made the adapter 😀
plus I wanted to see if I could do it too
Re: Spool Adapter
Looks like you did a good job
