[Closed] Slic3r rotate shortcut
Neolker
(@neolker)
Today works shortcut for rotating model around Z-axis for 45° left/CCW [L] or right/CW [R].
💡 Is it possible to add shortcuts of similar functionality for rotating around X and Y axis as well?
Posted : 28/03/2018 1:21 pm
martin.m25
(@martin-m25)
Re: Slic3r rotate shortcut
I'd second this. When I load stuff from ZBrush, the model is always lying on its back and I have to rotate in X by 90°. This is quite annoying if you have to repeat it a number of times.
- Martin
- Martin
Posted : 29/03/2018 7:45 pm
Petkanna
(@petkanna)
there will be 2 ways that i hope when this feature is implemented
1. Shortcut
Rotate in X, 90 degree each tap , shortcut : x
Rotate in X, -90 degree each tap , shortcut : shift+x
Rotate in Y, 90 degree each tap , shortcut : y
Rotate in Y, -90 degree each tap , shortcut : shift+y
or, we can combine together at zxc area?
2. Handle
there will be a handle to rotate, 45 at inner circle, 5 at outer circle
i don't know if those key already have shortcut or not
Posted : 06/04/2018 6:57 am
