[Closed] Power Pi4B via Einsy?
Stránka 2 / 2
Protoncek
(@protoncek)
RE: Power Pi4B via Einsy?
I did have connected with such cable but went back to USB. Reason? I update printer's FW via Octoprint plugin FW updater and this plugin can't reset einsy via this cable, thus FW update is not possible. USB connection does that.
In any case i don't see much difference in connection - at the end same two RX an TX pins are used on MEGS2560...
Napsal : 18/07/2020 2:54 pm
The reason I use the cable is I can turn it on and off with one switch.
Napsal : 18/07/2020 3:29 pm
@protoncek
That's right. To flash the FW you need to reset.
My printer is fixed in an enclosure and the USB port is placed outside the enclosure. There I have connected my Linux laptop, with which I do all the work on the printer (fw compiling, flashing...) and Raspi. GPIO connection speed with Octoprint is 250k baud and stable.
Napsal : 18/07/2020 4:43 pm
Stránka 2 / 2
