					                		Power Pi4B via Einsy? - Improvements (Archive)                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/power-pi4b-via-einsy/</link>
                <lastBuildDate>Sat, 13 Jun 2026 02:40:24 +0000</lastBuildDate>
                        <title>RE: Power Pi4B via Einsy?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/power-pi4b-via-einsy/paged/2/#post-230359</link>
                        <pubDate>Sat, 18 Jul 2020 16:43:18 +0000</pubDate>
                        <description><![CDATA[@protoncekThat&#039;s right. To flash the FW you need to reset.My printer is fixed in an enclosure and the USB port is placed outside the enclosure. There I have connected my Linux laptop, with w...]]></description>
                        <content:encoded><![CDATA[<p>@protoncek</p><p>That's right. To flash the FW you need to reset.<br />My printer is fixed in an enclosure and the USB port is placed outside the enclosure. There I have connected my Linux laptop, with which I do all the work on the printer (fw compiling, flashing...) and Raspi. GPIO connection speed with Octoprint is 250k baud and stable.</p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2020/07/USB_GPIO_1.jpg"><img class="alignnone size-medium wp-image-40120" src="https://forum.prusa3d.com/wp-content/uploads/2020/07/USB_GPIO_1-600x500.jpg" alt="" width="600" height="500" /></a></p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2020/07/USB_GPIO_2-2.jpg"><img class="alignnone size-medium wp-image-40132" src="https://forum.prusa3d.com/wp-content/uploads/2020/07/USB_GPIO_2-2-600x500.jpg" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/">Improvements (Archive)</category>                        <dc:creator>karl-herbert</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/power-pi4b-via-einsy/paged/2/#post-230359</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/power-pi4b-via-einsy/paged/2/#post-230326</link>
                        <pubDate>Sat, 18 Jul 2020 15:29:55 +0000</pubDate>
                        <description><![CDATA[The reason I use the cable is I can turn it on and off with one switch.]]></description>
                        <content:encoded><![CDATA[<p>The reason I use the cable is I can turn it on and off with one switch.  </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/">Improvements (Archive)</category>                        <dc:creator>cwbullet</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/power-pi4b-via-einsy/paged/2/#post-230326</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/power-pi4b-via-einsy/paged/2/#post-230305</link>
                        <pubDate>Sat, 18 Jul 2020 14:54:18 +0000</pubDate>
                        <description><![CDATA[I did have connected with such cable but went back to USB. Reason? I update printer&#039;s FW via Octoprint plugin FW updater and this plugin can&#039;t reset einsy via this cable, thus FW update is n...]]></description>
                        <content:encoded><![CDATA[<p>I did have connected with such cable but went back to USB. Reason? I update printer's FW via Octoprint plugin FW updater and this plugin can't reset einsy via this cable, thus FW update is not possible. USB connection does that. </p><p>In any case i don't see much difference in connection - at the end same two RX an TX pins are used on MEGS2560...</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/">Improvements (Archive)</category>                        <dc:creator>Protoncek</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/power-pi4b-via-einsy/paged/2/#post-230305</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/power-pi4b-via-einsy/#post-230275</link>
                        <pubDate>Sat, 18 Jul 2020 14:00:26 +0000</pubDate>
                        <description><![CDATA[@karl-herbertTrue.  It is not worth my time and that cable is very professionally done with a great protective sleeve.]]></description>
                        <content:encoded><![CDATA[<p>@karl-herbert</p><p>True.  It is not worth my time and that cable is very professionally done with a great protective sleeve.  </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/power-pi4b-via-einsy/#post-230275</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/power-pi4b-via-einsy/#post-230260</link>
                        <pubDate>Sat, 18 Jul 2020 13:40:41 +0000</pubDate>
                        <description><![CDATA[@charles-h13Of course you can also buy this finished product, but you can also easily build it yourself. In the beginning I used a self assembled ribbon cable as an alternative.something lik...]]></description>
                        <content:encoded><![CDATA[<p>@charles-h13</p><p>Of course you can also buy this finished product, but you can also easily build it yourself. In the beginning I used a self assembled ribbon cable as an alternative.</p><p>something like this one: <a href="https://www.amazon.de/14-polig-2-54mm-Steigung-Buchse-Flachband/dp/B012SPRYMG" target="true">https://www.amazon.de/14-polig-2-54mm-Steigung-Buchse-Flachband/dp/B012SPRYMG</a></p><p>what I would not recommend due to lack of stability are these jumper wires: <a href="https://www.amazon.de/Aukru-20cm-female-female-Steckbr%C3%BCcken-Drahtbr%C3%BCcken/dp/B00OL6JZ3C" target="true">https://www.amazon.de/Aukru-20cm-female-female-Steckbr%C3%BCcken-Drahtbr%C3%BCcken/dp/B00OL6JZ3C</a></p><p>I only use them on the plug-in board for experimental purposes.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/power-pi4b-via-einsy/#post-230260</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/power-pi4b-via-einsy/#post-230236</link>
                        <pubDate>Sat, 18 Jul 2020 12:34:51 +0000</pubDate>
                        <description><![CDATA[These cables make it easy!]]></description>
                        <content:encoded><![CDATA[<p><a href="https://littleredtoaster.com/collections/3d-printer-replacement-parts/products/prusa-i3-mk3-mk3s-raspberry-pi-connector" target="true">These cables</a> make it easy!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/power-pi4b-via-einsy/#post-230236</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/power-pi4b-via-einsy/#post-222817</link>
                        <pubDate>Tue, 16 Jun 2020 19:32:29 +0000</pubDate>
                        <description><![CDATA[I have attached a electrical distribution panel to the enclosure, from which I take the voltage for the printer, the raspberry, lights, ventilation and others from. The distribution panel an...]]></description>
                        <content:encoded><![CDATA[<div class="result-shield-container tlid-copy-target"><span class="tlid-translation translation" lang="en"><span title="">I have attached a <strong class="b5">electrical di</strong><strong class="b4">stribution</strong><strong class="b3"> panel</strong> to the enclosure, from which I take the voltage for the printer, the raspberry, lights, ventilation and others from.</span> <span class="" title="">The distribution panel and the individual components are specially secured with different fuses = only one 230V power cable to the printer(enclosure).<br /></span></span></div>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/power-pi4b-via-einsy/#post-222817</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/power-pi4b-via-einsy/#post-222814</link>
                        <pubDate>Tue, 16 Jun 2020 19:15:23 +0000</pubDate>
                        <description><![CDATA[@nikolai-ri agree 1000% 👍]]></description>
                        <content:encoded><![CDATA[<p>@nikolai-r</p><p>i agree 1000% 👍 </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/power-pi4b-via-einsy/#post-222814</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/power-pi4b-via-einsy/#post-222528</link>
                        <pubDate>Mon, 15 Jun 2020 19:37:54 +0000</pubDate>
                        <description><![CDATA[Posted by: @livinlarge0786 Before anyone asks, the reason I&#039;m pursuing this is that the idea of 2 separate power cables to 1 device (the printer, overall) is fundamentally wrong/unrefined in...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="182455" data-postid="218896" data-mention="livinlarge0786"><div class="wpforo-post-quote-author"><strong> Posted by: @livinlarge0786 </strong></div><p>Before anyone asks, the reason I'm pursuing this is that the idea of 2 separate power cables to 1 device (the printer, overall) is fundamentally wrong/unrefined in my mind. </p></blockquote><p>For me the printer and RPI are two different and separate devices. The one is always on (to get the updates and control the printer) and the other one is executing the tasks/prints. </p><p>Your setup is pushing the hardware out of specs. The einsy voltage regulator (LM25011MY) data sheet is saying:</p><table id="product-attribute-table" border="0" cellspacing="0" cellpadding="0"><tbody><tr><th>Current - Output</th><td>2A</td></tr></tbody></table><p>This is for everything connected to 5V. Means your setup might work under certain conditions but you shorten the live span of the components and risk instability/hardware failure. I wouldn't recommend it. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/">Improvements (Archive)</category>                        <dc:creator>Nikolai</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/power-pi4b-via-einsy/#post-222528</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/power-pi4b-via-einsy/#post-222360</link>
                        <pubDate>Mon, 15 Jun 2020 09:57:43 +0000</pubDate>
                        <description><![CDATA[Sorry, i messed up two commands.. correct is this:power of button:dtoverlay=gpio-shutdown,gpio_pin=7This will cause GPIO7 (pin 26) going LOW to do a shutdown;relay pin:dtoverlay=gpio-powerof...]]></description>
                        <content:encoded><![CDATA[<p>Sorry, i messed up two commands.. correct is this:</p><p>power of button:</p><p><strong>dtoverlay=gpio-shutdown,gpio_pin=7</strong><br /><strong>This will cause GPIO7 (pin 26) going LOW to do a shutdown;</strong></p><p>relay pin:</p><p><strong>dtoverlay=gpio-poweroff,gpiopin=27,active_low=1</strong><br /><strong>GPIO27 (pin13) will indicate the pi is running when: HIGH if active_low=1; LOW if active_low=0</strong></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/power-pi4b-via-einsy/#post-222360</guid>
