MK2 Pinda height template IDEA ONLY
Ben
 Ben
(@ben)
DO NOT TRY THIS YET. IT IS ONLY AN IDEA! THIS HAS NOT BEEN TESTED.
I came up with this. I am sure there is lots of other better designs or even more accuracy. Just an idea for a few less heartbreaks especially if Prusa is able to come up with a set distance from bed.
I have no idea how licenses work so I just click what makes sense 😕
The idea is you put this up against the mount and the adjust and tighten the pinda nut.
Thingiverse file. This is only set to 17mm so needs more. Would be interesting to know what the average is down from the mount to the tip of the pinda so I can adjust?
Thingiverse
http://www.thingiverse.com/thing:1771044
[attachment=1]IMG_20160914_201644[1].jpg[/attachment]
[attachment=0]IMG_20160914_201625[2].jpg[/attachment]
Posted : 14/09/2016 9:27 pm
ayourk
(@ayourk)
Re: MK2 Pinda height template IDEA ONLY
I like this idea, but I think that the height adjustment needs to be dependent upon the bottom edge of the nozzle.
Dimensions PNG
and an 8 inch (200mm) or greater caliper is recommended.
Posted : 15/09/2016 7:08 am
JohnnyricoMC
(@johnnyricomc)
IMO a good idea, could be useful for people who already have a printer and need something to help with PINDA probe attachment.
You should check https://creativecommons.org/licenses/ , it explains the various licences in people's English.
You chose a CC - attribution - no derivatives license.
Attribution means if anybody uses the design for anything, they have to remark you designed it. (i.e. if I take a photo of something and publish it under CC - attribution - ..., people using the picture anywhere have to state somewhere on there that I made the picture)
No derivatives means nobody is allowed to take your design and make a derivative work in any way. (in photograhy this would be like photoshopping)
Basically, anyone can print and sell this design, as long as they remark you designed it, but not make any adjustments.
Posted : 15/09/2016 2:39 pm
