MK2 HeatBed insulation
christophe.p
(@christophe-p)
Member Moderator
this is the inulation I put under the heatbed of my MK2. I prefer to tell you that it's not a game changer, but it help to get a bit faster heating and I hope that it will help to get higher temerature.
I planned to do it since the printer build, so I used the unmounted Y-frame to trace the area on a 10 mm wide cork tile.
I then used a dremel to carve all these area for 5~6 mm. I then put the tile on the frame and used a 2.5 mm2 electric wire to go through the tile at the screw position and used a drill to make a clean holes at these position. I did the same as well for the zip tie heads holding the linear bearing.
Once done, everything sit perfectly, with just enough room for the heatbed probe wires.
I'm like Jon Snow, I know nothing.
Posted : 10/07/2016 5:54 pm
christophe.p
(@christophe-p)
Member Moderator
Re: MK2 HeatBed insulation
I made some measurement before and after using Octoprint.
So with no insulation, I reach 110 °C in ~13 minutes
With the cork tile in place, I gain ~1minutes:
Having 2 graphs with different X axis scale is a bit tricky to compare, but it seems that the last degrees are reach faster, I presume the horizontal asymptote is a bit higher.
Posted : 10/07/2016 5:57 pm
JohnnyricoMC
(@johnnyricomc)
Interesting. So in terms of heat-up times for regular print temperatures the difference is negligible. Though perhaps power consumption-wise there might be a noticeable difference, as less heat is lost and it's probably easier to sustain the temperature?
Posted : 13/07/2016 7:53 pm
christophe.p
(@christophe-p)
Member Moderator
Just realised that the graph are in wrong order.
Sorry for that and I can't edit the post anymore (No idea why ??)
Posted : 16/07/2016 1:11 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Christophe
Posts can only be edited for a short period of time (can't remember why.
There was an instance a few months ago when one user had mad a mistake with the build and came on here asking all sorts of stupid questions. then a week lated edited all his posts and made me (I had attempted to answer his questions) look like a bit of an idiot...
I then complained about the situation and post editing is now only allowed for a small period of time.
So yes, your problem is my fault. Sorry...
Peter
Posted : 16/07/2016 2:22 pm
christophe.p
(@christophe-p)
Member Moderator
Ok Peter, I understand better now, I was sure it was not allways like that
Well, I'll need to triple check when putting multiple images, it's not the first time I mess up with image order :/
Posted : 16/07/2016 2:46 pm
jeff.w3
(@jeff-w3)
You are not worried about causing a fire?
Posted : 28/07/2016 3:46 pm
JohnnyricoMC
(@johnnyricomc)
Cork is naturally fire retardant, which is why it's commonly used for both acoustic and thermal insulation. It shouldn't be a problem.
On the odd event cork does catch fire, it doesn't release any toxic fumes.
Posted : 29/07/2016 2:27 pm
Ben
 Ben
(@ben)
Thats a cool ( 😳 ) idea. Will hopefully help loads with ABS. I seem to really struggle with ABS on the MK2 bed. Given up on ABS for the time being and doing only PLA.
The cork and maybe something around it to keep drafts off will work perfectly.
Posted : 31/07/2016 12:33 am
JohnnyricoMC
(@johnnyricomc)
ben.b, check the other thread about enclosures for the printer (named "Prusa + Box") for a possible solution to your abs woes. An enclosure would keep the heated up air concentrated, which could help prevent warping on ABS prints (and might also help with noise).
Posted : 31/07/2016 6:12 pm
christophe.p
(@christophe-p)
Member Moderator
Cork is rated for temperatures from -180°C up to more than 110°C, in addition, it's very unlikely burnable (Class B).
But the concern is that from the initial cut and installation to the day to day usage, I observed some deformation, which make it touch the Z frame during X moves. I had to cut it more to avoid that.
Posted : 02/08/2016 6:51 pm
tobias.k3
(@tobias-k3)
Alternatively there are aluminium covered fibre glass mats available, normally used to cover heat sensitive parts in car engines. About 10 € at ebay. Those might shield the heat better, decreasing heat time further.
I'll post my experience if I test these in the near future.
PRUSA MK2
- Noctua fan 40mm
- MK2/MK3 hybrid extruder
Posted : 26/03/2017 6:01 pm
vitor.j
(@vitor-j)
Hi christophe.
have you tried to just put a cardboard sheet over the bed while it heats?
Posted : 27/03/2017 3:43 pm
christophe.p
(@christophe-p)
Member Moderator
Hi Vito,
nope, I just have the cork on one of my printer, the one I dedicate to ABS printing, I never tried cardboard.
Posted : 27/03/2017 4:45 pm
3DMason
(@3dmason)
I can shave about 3 minutes from my normal warm up time by placing a sheet of thick cardboard over the bed surface during warm up. It acts as an insulator. Cut the cardboard box that came with your printer to the size of your bed. No bed modifications required. Just make sure you remove the cardboard once your bed temperature is reached!
Posted : 27/03/2017 9:35 pm
krzysztof.z
(@krzysztof-z)
Hello Christophe!
What can you say about your upgrade after nearly a year later?
Have you observed more deformation? Haven't you unbuild it for some reason?
Thanks in advance for your answer!
Posted : 24/05/2017 10:07 pm
christophe.p
(@christophe-p)
Member Moderator
Hi Krzysztof,
Since I cut the side of the cork so that cork does not overtake the bed I didn't had any further issue.
And yes, that's soon 1 year, time flies !!
Posted : 30/05/2017 10:47 am
