Re: Mk2 cable chains
Will Rambo case for X & Y works great if I have a) Igus bearings with casing which rise heated bed for a few milimeters and b) printer box only 55 cm long?
And what about box without PT100? And last one - no udestarstand new X cable mounting part 🙁
Come into the Slack group and all your questions will be answered: http://slackin.codehemi.com/
Are there any new models for the MK2S version released yet? 🙄
PRUSA MK2
- Noctua fan 40mm
- MK2/MK3 hybrid extruder
I have made a few rambo cases, so yes.
Can someone please post a pic of the cable chain attached to their bed?
I'm just reading this article, so I'm trying to catch up and figure out what the latest parts are.
Additionally, is there a reason why you guys did not find it necessary to create a chain between the Rambo and the x axis motor?
Thanks for all your help!!
Dana
I belive the X Carriage design I referenced in the previous post is yours. Can you provide some input on how it connects? Thank you.
I don't see a lower bearing cover in that picture. That's the missing piece to connect the arm and also secure the lower bearing. There are no zip ties used in this design.
Appreciate the feedback. Working now! Thank you.
is somebody planning an adaptation for the MK3 ?
Are the models for the MK3 out yet?
EDIT: I guess they are out as of 8 days ago: MK3 Parts
just did the adaptation for the MK3, very quick and dirty, but it works:
https://www.thingiverse.com/thing:2731943
The rest of the parts are the same as for the MK2
