Wobble help for tall, thin vase mode prints
mwcz
 mwcz
(@mwcz)
I'm trying to print this telescoping sword for a Halloween costume, but I'm having trouble with wobble.  The sword blade segments are tall, thin, PETG, and vase mode, so the wobble factor is high.  I had to scale it down to 80% size to fit in the MK3's print volume and my kids' hands, but that also exacerbated the thinness.  This seems to be a worst-case scenario for wobble, so I'm looking for any advice on how to get these printed straight and true.
Things I've done:
  1. As recommended by the print instructions, I setting the extrusion width to 0.8mm (w/ 0.4mm nozzle) for thicker, more stable walls.
  2. Added a wide brim (inner and outer) for extra adhesion and hopefully stability.
  3. Slowed down the print speed from default 45mm/s to:
    • 35mm/s - helped a small amount
    • 10mm/s - helped a medium amount
    • 3mm/s - currently running, agonizingly slow, and I can already see some wobble starting around 70mm height.
  4. Surface stability: the printer is on a very heavy cabinet with no wobble.
Things I haven't done:
  1. Have not gradually decreased print speed with Z height.  I tried, but I couldn't find a way to make the print speed slow down linearly with Z height in PrusaSlicer.  I could only add one height range modifier, not multiple (is there a way?).  I also tried multiple Slabs with speed settings but it was very tedious.
  2. Have not added supports, because vase mode.
  3. Have not tried more rigid filament like PLA, because it needs to be durable for dueling.
  4. Have not done any printer maintenance/calibration like checking belt tension, etc, because I'm not sure where to start.
That's the situation, and here are some pictures.  The print is oriented like this:
This was the first print, at 45mm/s.
Close-up.
The slower print speeds diminished the problem somewhat, but it's still very noticeable.
Many thanks for any help!
Veröffentlicht : 11/10/2025 4:36 pm
mwcz
 mwcz
(@mwcz)
RE: Wobble help for tall, thin vase mode prints
Update, I started going through the regular maintenance guide and found a scratch on the top X axis rod.  I'm trying the print again in a part of the print bed that won't overlap with the scratch.
Veröffentlicht : 11/10/2025 6:23 pm
I haven't tried that file but I did print an earlier model after giving in to pester power ... it lasted about three minutes so
don't be too optimistic.
Sometimes a print wobble in a tall, thin part is exacerbated by resonance, a small change in speed, faster or slower, might be enough to de-tune the problem.
You may be able to rotate the rod by a few degrees, enough to move the rough spot away from the bearing point until you can do serious repairs.  There is a possibility your linear bearing(s) is/are damaged as well as the rod but both are available as spares.
Veröffentlicht : 11/10/2025 7:21 pm
mwcz
 mwcz
(@mwcz)
Thanks for your message, @diem.  I have tried many different speeds, see the OP, and the difference was noticeable but minimal.  The one thing I didn't try was going faster.  After moving away from the scratched area, the print was much better.  There's still a bit of wobble, but far less.  I also discovered several similar scratches in other parts of the rod.  Maybe dry or damaged bearings. 🙁
I'll replace the rod and clean or replace the bearings, add some new lubricant, and hopefully it'll be good as new.  Thanks again @diem.
Veröffentlicht : 11/10/2025 8:45 pm
