Why does the printer need to travel ?
In order to remove surface defects when printing with silk PLA, I try to reduce the number of travels and retractions as much as possible. One idea is to have a solid part and set the infill to 0% So that there is a constant number of perimeters on the outside, with no gaps to fill (so no need for the nozzle to travel to fill the gaps). Now something strange happens when printing a tube with fins: the slicer has the nozzle travel when doing the seaming. (see picture). Is there a way to force the slicer to do the seaming "on the spot" to avoid the travel and retraction? I see no reason in the geometry of the part why this would not be possible.
RE: Why does the printer need to travel ?
That might be deliberate, historically there's always some overextrusion at Z-seams and this could be to mitigate the additive error from several seams in the same location.
This does not happen if the part is cylindrical. Why would you need to travel only when there is a specific geometry? (In this case the fin)
I removed the fillet between the fin and the tube, to see how the slicer reacts. And reacting it does, but now how I would like...
With the seaming set to "rear", from the base of the tube I have a nice vertical seaming. Then when the fins get longer the nozzle starts to jump to the other side when doing the seaming. Is there a logic behind this behavior?
