[Solved] Tried a Cold Pull, still having issues
BluesTraveller
(@bluestraveller)
I tried the cold pull three times but I think it is still jammed or is this a idle screw or z-axis issue?
Best Answer by Diem:
That looks like damp filament.
On page: https://help.prusa3d.com/en/article/pvb_196708
It says:
PVB is very prone to absorbing moisture. Always put the spool back inside the bag with silica gel or let it dry for 4 hours at 60 °C before printing!
Posted : 07/11/2021 3:15 pm
RE: Tried a Cold Pull, still having issues
It could be both.  What filament are you using?
I would go back to a Z of zero and try again.  If it still jams, try adjusting your tension screw.
Posted : 07/11/2021 3:23 pm
BluesTraveller
(@bluestraveller)
PVB filament.
Thank you for the reply.
Posted : 07/11/2021 3:27 pm
Honestly, I have a sample and have not used that filament.  This image above looks like it might be underextruding or damp.
Posted by: @bluestraveller
PVB filament.
Posted : 07/11/2021 3:58 pm
BluesTraveller
(@bluestraveller)
Damp as in the humidity around the printer is too humid?
Posted : 07/11/2021 4:18 pm
Zoltan
(@zoltan-d-2)
Member Moderator
Is it your first print?
Can you please describe your issue according to this? https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/we-want-to-help-you-you-have-to-tell-us/
Posted : 07/11/2021 5:06 pm
BluesTraveller
(@bluestraveller)
Thanks for the reply.
No, it is not my first print.
Printer: i3 MK3 which I bought fully assembled.
Printer setup: 215/75 standard setup.
Slicer: I use the Prusa slicer but have not attempted a new print since I cannot get a good 1st layer calibration.
Filament: Clear PVB, new Black PLA filament will arrive tomorrow.
Issue started when I walked away during my last print and the filament got too much slack in it and it tied itself in a knot and prevented it from feeding into the extruder. I tried the cold pull three times before re-running the calibration wizard. I got to the 1st layer calibration and the picture in the original post is what I see happen now.
Posted : 07/11/2021 5:18 pm
It says:
Posted : 07/11/2021 7:51 pm
BluesTraveller
(@bluestraveller)
Thank you, you were correct. Got new PLA spool and it is printing just fine again.
Posted : 08/11/2021 11:42 pm
