Top layer too wide
Hello,
I have the following problem: as soon as the top layer infill starts in my object, the top layers become too wide. That means my part is approx. 0.2 mm wider at the top than it is is at the bottom. Other than that, my top layer appears to be good. I had some problems with rough top layer that I solved by changing the top layer extrusion multiplier from 0.4 mm to 0.44 mm. That gave me a more smooth and uniform texture on the top layer. But for my understanding that should not have any impact on the dimensions of the top layers? Is the solid infill pushing the outer layers outwards?
Best Regards
Veröffentlicht : 22/05/2019 4:51 pm
