Top Infill Aligned Rectilinear, why just diagonal? Can I choose rotation? I need it horizontal or vertical aligned to the panels
I'm printing this panels for a doll-house cabinet and would be great if the top infill will follow the orientation of those panels, so horizontal or vertical. On a previous work I solved this by rotating the object by 45°, but this can't be done here as the wole panel is too big.
Can I choose the angle of Top Infill Aligned Rectilinear or there are some other options?
Napsal : 27/01/2025 3:23 pm
RE: Top Infill Aligned Rectilinear, why just diagonal? Can I choose rotation? I need it horizontal or vertical aligned to the panels
Change the orientation to 0 degrees or 90 degrees in the infill menu
Joan
Napsal : 27/01/2025 4:44 pm
